random rpm increase and decrease at idle
  • karim
  • karim's Avatar Topic Author
9 years 2 months ago - 9 years 2 months ago #12220 by karim
Dears,
Today, I cleand my injector and replaced the filters inside them. The car has witnessed dramatic performance change but the RPM makes random movement at idle. Any info? does bad alt diod make this? that is my guess.
Thanks for any info
Last edit: 9 years 2 months ago by karim. Reason: grammar
9 years 2 months ago #12226 by Noah
Replied by Noah on topic random rpm increase and decrease at idle
I moved this to the repair questions section for you, you will get more help.;)
9 years 2 months ago #12234 by matt.white
Replied by matt.white on topic Re:random rpm increase and decrease at idle
What sort of car? Does it ever return to the correct idle speed or is it always high? Did you clean the throttle body? Is it possible you've left a hose or fitting off somewhere and the engine is getting unmetered air allowing it to idle high?
  • karim
9 years 2 months ago #12238 by karim
Toyota avalon 2012. The throttle was clean. all hoses are in place. The RPM returns to normal but it rises and goes down.
Do you think that the TPS must reset?
Thank you
9 years 2 months ago #12244 by matt.white
Is that an electronic throttle body? There may be an idle relearn available.
Does it also have coolant flowing through it? If so, make sure these are hot and the coolant is full. It may have air in the system allowing the air bypass to cool and open up allowing the revs to increase.
  • karim
9 years 2 months ago #12250 by karim
Yes, It is an electronic throttle with twin hose on it for cooling. May be there is air as you said. Any recommendation to empty the air inside the coolant?
Thanks for your help
9 years 2 months ago - 9 years 2 months ago #12262 by matt.white
Replied by matt.white on topic random rpm increase and decrease at idle
We don't get an Avalon in Aus. We do get an aurion which may be similar which has a 2gr-fe engine. There's a bleeder in the v to bleed air from the system.
There's no check engine light is there? Can you feel these hoses and see if they're hot? They should warm up as quickly and stay as hot as the heater hoses into the firewall.
Last edit: 9 years 2 months ago by matt.white.
