2006 Porsche Cayenne S 4.5 V8, P0441, P0300, P2189
- kostelectronics
- Thank you received: 7
9 years 2 months ago - 9 years 2 months ago #12283
by kostelectronics
2006 Porsche Cayenne S 4.5 V8, P0441, P0300, P2189 was created by kostelectronics
Hi Guys and greetings from Switzerland!
I'm fighting with a friend's car. Porsche Cayenne S 4.5 V8.
I grabbed the following DTC's:
P0441 - EVAP incorrect purge flow
P0300 - Random misfire
P2189 - System too lean at idle (Bank2).
I've already changed a bad PCV few months ago, after this, the car ran fine till now.
Now, the engine shakes at idle and under load, misfires happen randomly too.
I suspect a bad (stuck open or Close) tank vent valve for the P0441. Can this cause the other DTC's too (P0300 + P2189)? Or do i fight with more Problems here? does anybody can help me to fix this?
BR Matthias
BR Matthias
Last edit: 9 years 2 months ago by kostelectronics.
9 years 2 months ago - 9 years 2 months ago #12290
Replied by Andy.MacFadyen on topic 2006 Porsche Cayenne S 4.5 V8, P0441, P0300, P2189
You can clamp off or disconnect EVAP hose at the manifold and and block off the hole in the manifold see what happens, BUT what would help is to know the fuel trims short and long term at idle and raised rpm (say 2,000 to 2,500 rpm). If the engine becomes more lean at raised RPM and load it points more towards a faulty MAF sensor.
Last edit: 9 years 2 months ago by Andy.MacFadyen.
The following user(s) said Thank You: kostelectronics
- kostelectronics
9 years 2 months ago #12293
by kostelectronics
Replied by kostelectronics on topic 2006 Porsche Cayenne S 4.5 V8, P0441, P0300, P2189
Thank you!
I will check the fuel-trims again. But as i remember, they looked good so far. I will repost after checking!
- cheryl hartkorn
- Thank you received: 130
9 years 2 months ago #12296
by cheryl hartkorn
Replied by cheryl hartkorn on topic 2006 Porsche Cayenne S 4.5 V8, P0441, P0300, P2189
i would say a stuck open purge valve.
