vw golf plus, 2006 mod. Unable to reset steering angle after battery disconnect.
- Inge Jeppesen
- Ford master tech.
- Thank you received: 3
9 years 2 months ago #12504
by Inge Jeppesen
vw golf plus, 2006 mod. Unable to reset steering angle after battery disconnect. was created by Inge Jeppesen
Hello.
This one is a nasty one. We had it in for a repair on the alternator, changed the drive wheel on it. Had the battery disconnected during.
When I reconnected and startet the car, the ESP light and the yellow steering wheel lamp was lit. Have tried many things to reset it. But cannot. Error codes are: 02546 and 00778.
Have a generic tester, have also tried at a dealer With the vag com.
Any ideas?
Any ideas?
- Ben
- Thank you received: 215
9 years 2 months ago #12505
by Ben
Replied by Ben on topic Re:vw golf plus, 2006 mod. Unable to reset steering angle after battery disconnect.
Read here
wiki.ross-tech.com/wiki/index.php/02546
and here
wiki.ross-tech.com/wiki/index.php/00778
I'm sure you need to perform the adaptation with a vag com I'm not sure your dealer is doing it correctly
- Ben
9 years 2 months ago #12506
by Ben
How many miles have you driven it like this? Some people report success just driving it down a straight road for a short time . I've never tried so I can't confirm that.
- Doc
- Sharing the little I know
- Thank you received: 12
9 years 2 months ago #12514
by Doc
Youtuber specialising in Diagnostic techniques, sharing skills and helping technicians be the best they can be #Picoflu
Replied by Doc on topic Re:vw golf plus, 2006 mod. Unable to reset steering angle after battery disconnect.
Do not start the system function test, it can sometimes be a very finicky process to complete.
Make sure you only carry out the appropriate basic settings.
hope this helps
Doc...
hope this helps
Doc...
