Hard start in the morning
  • Bobby10
  • Bobby10's Avatar Topic Author
9 years 1 month ago #12890 by Bobby10
Hard start in the morning was created by Bobby10
Hyundai Accent 2005 1.3lt
The vehicle has difficulty starting in the morning (it usually takes 4 to 20 times to crank in order to start)
When I spray propane or brake cleaner in the intake the car starts immediately.
It sounds good at idle but when I press the gas pedal it hesitates and shuts off.
If I wait for couple of minutes at idle it's ready to go.
The fuel pump and fuel filter has been replaced.
9 years 1 month ago #12892 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Hard start in the morning
You have established the problem is lack of enrichment at cold start. I would start by reading the coolant temperture data PIDS with the engine cold it should be close to ambient temperature, if it reading high you won't get cold start enrichment.
The next thing I would check is fuel pressure: Check how the fuel pressure a builds when you crank the engine , if it dosen't build to specificified pressure quickly it points to a fuel pressure problem.
  • Bobby10
9 years 1 month ago #12923 by Bobby10
Replied by Bobby10 on topic Hard start in the morning
The ECT sensor reads ambient temperature in the morning.
The vehicle has new fuel pump and fuel filter, the fuel pressure shouldn't be OK?
