Crank no start...I may have fried my computer
  • wyatt
  • wyatt's Avatar Topic Author
10 years 2 months ago #1318 by wyatt
10 years 2 months ago #1323 by Rukerin
Replied by Rukerin on topic Crank no start...I may have fried my computer
Did you try measuring the signal at the Ignition Control Module? I had the same problem yesterday on a Chevy and found the white and black wire was open , you could try continuity on the white and black wire that goes from the Ignition Control Module to the Coil. Hope this helps.
  • wyatt
10 years 2 months ago #1324 by wyatt
Actually I didn't think to do that because this issue was so sudden I'm assuming I burned something up. Your right however, I shouldn't assume anything and will check that tomorrow. Thanks for that reminder.
  • wyatt
10 years 2 months ago #1341 by wyatt
The video of the steps I took has been posted. I'm working on part two with the fix! Thanks for the help.
10 years 2 months ago #1354 by Noah
Good video quality. Helps to see the steps you took during the diagnosis.
  • wyatt
10 years 2 months ago #1355 by wyatt
Thank you Noah. I have part two (and the fix) video ready. I'll post it here in hopes it will help others.
10 years 2 months ago #1363 by Noah
Nice, always rewarding when they fire up :)
You could get more definition with the Vantage by using the "Waveform Viewer" function instead of the Multimeter function. From there you can set a shorter time base. Not that it was necessary in this instance, just for future reference.
The following user(s) said Thank You: wyatt
  • wyatt
9 years 9 months ago - 9 years 9 months ago #5064 by wyatt
So after 5 months of fixing the crank, no start problem I now have a new issue. The truck will crank but will not start in cold weather. Back to the drawing board.
Last edit: 9 years 9 months ago by wyatt. Reason: Realized I did in fact respond via a video to show the fix.
