A more general automotive question not vehicle specific
  • Hollumsd
  • Hollumsd's Avatar Topic Author
9 years 1 month ago #13045 by Hollumsd
If a newer vehicle with a dead battery is needing a jump off from another vehicle will increasing the revs on the "jumper" vehicle damage the alternator on the "jumpee" vehicle?
9 years 1 month ago #13048 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic A more general automotive question not vehicle specific
With modern systems I am pretty careful I never have both donor and client engines running at the same time and never connect and disconnect with either engine running. Best practice is to connect up with both engines key off engine off then start the donor and leave it running for a few minutes then go engine off key off and try and try and start the client, if the cient starts run for a few minutes, then key off engine off key off disconnect.
9 years 1 month ago #13060 by matt.white
Same as Andy, except I'm ok disconnecting with them both running. My theory is the voltages are going to be close to equal to each other so a spike isn't likely. Just my thoughts.
