IAC raising rpms
- Bigdan120
9 years 1 month ago #13156
by Bigdan120
IAC raising rpms was created by Bigdan120
2001 Pontiac Aztek 3.4.
The IAC is raising rpms even though the computer shows it's requesting a lower rpm.
This only occurs when cooling fans kick on at 223 degrees.
I have a Modis but still learning.
Help...
Help...
9 years 1 month ago - 9 years 1 month ago #13163
Replied by Andy.MacFadyen on topic IAC raising rpms
How high is it raising the RPM ? is it excessive ?
A lot of system raise the RPM when th fans are on because of the extra load on the alternator, fans take a lot of current
Also higher RPM is used by some system to increase fuel flow through the fuel rail and prevent vapour lock in the fuel rail.
Last edit: 9 years 1 month ago by Andy.MacFadyen.
- Bigdan120
9 years 1 month ago #13178
by Bigdan120
Replied by Bigdan120 on topic IAC raising rpms
It will raise rpms to 3500 or more. Iac and cooling fans relay repeatedly click.
- Bigdan120
9 years 1 month ago #13179
by Bigdan120
I tried impinging grounds at computer for fans this changed nothing. New iac new plug end on it. New computer last year. New cooling temp switch and plug. Check iac wiring seems good..
9 years 1 month ago #13180
What happens when you disconnect the IAC ?
- Bigdan120
9 years 1 month ago #13181
by Bigdan120
It will stay at whatever point it is at in the rpms. It does not do anything weird till the fans kick on or it reaches 223.
9 years 1 month ago #13207
The one has me really puzzled, unless somebody has encountered this before the only way forward is to look at how the ECU is commanding the IAC
- Bigdan120
9 years 1 month ago #13219
by Bigdan120
It actually says a lower command on com. It raises itself..
- Big Dog50001
9 years 1 month ago #13226
by Big Dog50001
Replied by Big Dog50001 on topic IAC raising rpms
You probably have already done it, but I would look at as many data PIDs as I can, MAF/MAP/ECT/Fuel Trims etc and look for anything out of the ordinary when the idle changes.
- Bigdan120
9 years 1 month ago #13231
by Bigdan120
I was looking into it and it looks like voltage is off to map with koeo or koer both like 4.73. Gotta no a wire causing it.. I have to get a pin out of pcm...
