1999 mb C180 no injector pulse
  • Baraka
  • Baraka's Avatar Topic Author
9 years 1 month ago #13556 by Baraka
1999 mb C180 no injector pulse was created by Baraka
I've done series of test like checking if we have a good ECU ground and also we have a constant power on the injectors
Can an immo problem cause this?
9 years 1 month ago - 9 years 1 month ago #13558 by juergen.scholl
Replied by juergen.scholl on topic 1999 mb C180 no injector pulse
Does the car crank? Do you have a rpm signal if it turns over?
Do you have comunications with the imm?
On most mercedes of this vintage an immo problem will inhibit the starter....
Last edit: 9 years 1 month ago by juergen.scholl.
  • Baraka
9 years 1 month ago #13569 by Baraka
Replied by Baraka on topic 1999 mb C180 no injector pulse
It only starts when you bypass fuel to the intake manifold, that's when I concluded we have to switching signal from the ecu to injector my question is what those the ecu depend in to switch those injectors.... That my big question
9 years 4 weeks ago #13607 by juergen.scholl
Check the cam and crank signals and verify the immobilizer status.
