P0171 code/ runs lean
- bensauto
9 years 3 weeks ago #13776
by bensauto
P0171 code/ runs lean was created by bensauto
Hello! I'm working on a 2011 Nissan Altima 3.5L engine. This car sets a p0171 pretty consistently. Trims indicate a lean condition on both banks although bank 1 shows a slightly worse lean condition. For example: Bank 1 will read 128 n Bank 2 125. Trims get a little better @ 2500 rpms but not much @ all. A/F ratio sensors seem to be reading accurately(I can add fuel and they move rich, voltages look good) I've replaced MAF thinking it was skewed, no help. Smoked intake, checked for vacuum leaks. Ran off different fuel supply. Fuel pressure is good at 51 psi. Performed injector balance test(they're good). While driving today p0171 did not set but once it idled in the shop a bit then it did. Any thoughts would be appreciated. Sorry if I'm not clear on something...ask n I'll try to clear it up. Thanks
9 years 3 weeks ago #13781
Replied by Andy.MacFadyen on topic P0171 code/ runs lean
It really sounds like a vacuum leak they can be devils to find especially on a V engine. Check not only the manifold and air duct after the MAF but check the air duct to the air filter.
- cheryl hartkorn
- Thank you received: 130
9 years 3 weeks ago #13783
by cheryl hartkorn
Replied by cheryl hartkorn on topic P0171 code/ runs lean
have you checked the purge valve for a leak?
- bensauto
9 years 3 weeks ago #13785
by bensauto
Replied by bensauto on topic P0171 code/ runs lean
This car is missing the intake "pipe" that runs from the air box to the grille. Are u thinking something like this could create lean conditions?
- bensauto
9 years 3 weeks ago #13786
by bensauto
I pinched off the rubber hose to the purge solenoid...it didn't make any difference in the trims.
- cheryl hartkorn
9 years 3 weeks ago #13801
by cheryl hartkorn
did you smoke the intake cold? what about a leaking brake booster? worth a check
9 years 3 weeks ago #13804
As long as the air filter and its' case are intact I would think it would be Okay, but I always keep in mind any change to the induction can throw the MAF calibration off.
- John Clark
- Thank you received: 46
9 years 3 weeks ago #13873
by John Clark
Replied by John Clark on topic P0171 code/ runs lean
How many miles on this vehicle? On my 08 Odyssey I had some lean conditions that, while not bad enough to throw a code, turned out to be skewed O2 sensors (AF sensors upstream and regular O2's downstream.) Vehicle had 170K and four new O2's finally solved the problem and it runs like a new car.
9 years 3 weeks ago #13879
Replied by Tyler on topic P0171 code/ runs lean
I guess the missing tube is possibly throwing the MAF off... But, that tube is well ahead of the filter, correct? Unless there's something in the filter that's screwing with laminar airflow across the sensor.
I see that you smoked the intake with no luck. Have you happened to try carb/brake cleaner? I usually hate using those to find leaks, but it may be worthwhile in this case. There's a vacuum canister on the front of the intake that's part of an intake butterfly system. There's a check valve in the hoses that'll prevent smoke from showing the leak, but can be found with spray.
- Tutti57
- Thank you received: 254
9 years 2 weeks ago #13933
by Tutti57
Replied by Tutti57 on topic Re:P0171 code/ runs lean
I saw one if Paul's videos where a missing air box caused a lean condition. That might not be the same though. Could it be missing a screen in front of the maf sensor?
- AlphaMM
9 years 2 weeks ago #13939
by AlphaMM
Replied by AlphaMM on topic Re:P0171 code/ runs lean
o2 can make it run lean as well, have you checked it; at higher rpm does it go back to normal?
Sent from my SM-G900I using Tapatalk
