STFT 1 and 2? whats the 2nd one?
  • Agnewdautos
  • Agnewdautos's Avatar Topic Author
9 years 3 weeks ago #13806 by Agnewdautos
STFT 1 and 2? whats the 2nd one? was created by Agnewdautos
Hi there team. Learning heaps so thank you all so much!
Ok, this is an Australian car. I am in New Zealand and have a small country garage business...
2003 BA Ford Falcon. It has a 4.0 litre straight 6. Super common down here. My question is. Looking at the scan data, fuel trims, there are two STFT readings. STFT1 and STFT2. Our number 2 reading is positive as it can be. I went looking for an air leak and indeed I did find one. I thought it would be a fix. But my numbers went straight back up there. STFT1 and our LTFT are normal. Why are there 2 STs?
I guess I could still have an air leak some where as well. There are no DTCs. This is a speed density engine. There is only one 02 above the cat. There was a crack at the cat that we have fixed. 02 readings look good.
Any ideas?
Thanks all
Allan
9 years 3 weeks ago - 9 years 3 weeks ago #13811 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic STFT 1 and 2? whats the 2nd one?
It is almost certainly spurious , although on most straight 6 engines have the injectors split into two banks if there is only one upstream O2 sensor there can be only one short term adjustment.
My guess is the basic ECU is shared with a V8 and this is a PID that is left floating you could also be looking a B1S2 fuel trim which again is a floating value on 99.99% of vehicles.
This sort of issue is not unknown on my daily driver if I scan the ECU using manufacturer mode I get a spurious oil temperature high PID but the engine hasn't got an oil temperature sensor, the spurious reading only occurs in manufacturer mode not OBD2
Also I am pretty sure if you picked any random older Ford there is a 1 in 3 chance if you looked for at vacuum leak you would find at least a minor one,
Last edit: 9 years 3 weeks ago by Andy.MacFadyen.
The following user(s) said Thank You: Agnewdautos
9 years 3 weeks ago #13823 by Tyler
Replied by Tyler on topic STFT 1 and 2? whats the 2nd one?
Andy.MacFadyen wrote: could also be looking a B1S2 fuel trim which again is a floating value on 99.99% of vehicles.
I was thinking the exact same thing. :lol: Such a useless PID.
9 years 2 weeks ago #13910 by bruce.oliver
Replied by bruce.oliver on topic STFT 1 and 2? whats the 2nd one?
If it runs good and there are no codes and all the monitors have run, why try to fix it?
Also a vacuum leak on speed density won't affect fuel trims.
At first I thought maybe it was downstream fuel trim but I would have to agree that it's a false PID
