96 dodge grand caravan
  • ArainasBoomah
  • ArainasBoomah's Avatar Topic Author
9 years 3 weeks ago #13808 by ArainasBoomah
96 dodge grand caravan was created by ArainasBoomah
Had a start then die. Would change the starter relay and run for a day or two then back to start/die. Just got this vehicle. Changed the cam shaft sensor., fuel pressure is good, spark good, runs some with fluid spray in air flow.
9 years 3 weeks ago #13824 by Tyler
Replied by Tyler on topic 96 dodge grand caravan
How's your injection pulse during the start/stall? Possible anti theft issue taking injection pulse away after startup. This would certainly account for how it runs on alternate fuel and has good fuel pressure.
The following user(s) said Thank You: ArainasBoomah
  • ArainasBoomah
9 years 3 weeks ago #13837 by ArainasBoomah
Replied by ArainasBoomah on topic 96 dodge grand caravan
Yes, am sure it is the anti-theft. Only I don't know what to do about it. I have changed the instrument cluster, as it was not working properly. In the manuel it doesn't even talk about the anti-theft circuit.
9 years 3 weeks ago #13848 by Chad
Replied by Chad on topic 96 dodge grand caravan
You could try to reset security by disconnecting BOTH battery cables and touching them together for a few seconds.
  • ArainasBoomah
8 years 11 months ago #14764 by ArainasBoomah
Oh, thank you for your help. I am sure it's the anti-theft. I just don't know where to go from here.Before I started changeing parts, (I know), I would swap the starter relay, near the battery, and it would run for maybe a day maybe two. I have done the battery cable reset. I've changed the instrument cluster and the cam sensor. I am pretty much DONE with buying parts. The lock mechanism, in the lift gate, does this growl thing and won't unlock right away. I have to continue to unlock it. I tried disconecting that. Nothing.
