2003 lincoln towncar no crank no start
  • Cournoyer
  • Cournoyer's Avatar Topic Author
9 years 1 week ago #14128 by Cournoyer
2003 lincoln towncar no crank no start was created by Cournoyer
After watching your video How to troubleshoot a starting system (bad ignition switch) - Dodge Neon I have a Question: I recently bought a 2003 Lincoln Towncar 69k miles garage kept. nothing was wrong the first 1200 miles... then one day no crank no start last week I changed out my ignition switch thinking that was the problem ...(electrical side) under dash on column only $20 it was not the problem . I also can crawl under car and jump the starter off the positive post of starter to start post so i know starter battery and solenoid work that is why i changed ignition switch. ( I also removed starter and had it bench tested at the auto parts store (works fine only 69k miles on it) and then reinstalled) when I pull out the starter relay under the hood in fuse box and put a test light in terminals after checking ground and making sure light works ( it did) There is no power in any of the 4 pins of the relay terminal and when in run and crank position there is no power in any of the 4 pins in the terminal . Does this leave me with a PCM problem because that controls neutral safety and starter signal? I have checked all fuses and all working . The dash cluster warning lights also do not light up when key is turned to run and there is no security light flashing in cluster. However the flashing light for security does shut off after 3 seconds like it is supposed to on the dash when key is in run right before crank position. please help me confirm it may be pcm , Thanks Rich
REPLY
9 years 1 week ago #14135 by Chad
Replied by Chad on topic 2003 lincoln towncar no crank no start
In the Battery Junction Box, Check Fuse 101. It is a 50 amp fuse.
  • Cournoyer
9 years 1 week ago #14138 by Cournoyer
Replied by Cournoyer on topic 2003 lincoln towncar no crank no start
what if the power feed coming into the ignition switch has no power? but i do have power coming to the 50 amp fuse in fuse block . what does this tell me? anyone? thanks
9 years 1 week ago - 9 years 1 week ago #14139 by Chad
That would suggest a blown fuse.
Or, an open in the yellow wire.
Last edit: 9 years 1 week ago by Chad.
  • Cournoyer
9 years 1 week ago #14140 by Cournoyer
thanks , i am going to check for an open in the yellow line because the fuse is good #101 50 amp could you post the other diagrams it said 2 of 3 different diagrams
  • Cournoyer
9 years 1 week ago #14141 by Cournoyer
does those other diagrams show the pcm coming into the yellow line near the ignition switch?
9 years 1 week ago - 9 years 1 week ago #14142 by Chad
Cournoyer wrote: does those other diagrams show the pcm coming into the yellow line near the ignition switch?
No.
With the starter relay removed, there should be 12v terminal #30. If you have no power here, the problem is BEFORE the ignition switch.
9 years 1 week ago #14143 by Chad
And, if there is no power on terminal #86, with the key in the "START" postion, I would say, the problem is BEFORE splice s163.
  • Cournoyer
9 years 1 week ago #14146 by Cournoyer
that #30 is dead at the relay so i will check that yellow wire thank you
  • Cournoyer
9 years 1 week ago #14291 by Cournoyer
I removed positive post bolt on fuse tray and flipped tray to look under it and all wires look good at the relay 302 on the underside. After that i put tray back in and reconnected positive post on fuse tray box and hooked up the battery terminals . I now have power (12v) at the #86 relay post when in start position. I also have power at the number 30 post (12v) with the key in run .(is there supposed to be power at #30 with key in run ) when i check the power on the start post solenoid wire down by the starter I get 11.4 volts in start position with it not connected to the solenoid . when i connect it i get less than 1 volt while in start position on the key. I did cut the start post wire back and put a new connector and no difference car wont start. ps i did make a jump wire 10 gauge with new ring post connector and hooked it to start post on starter and with the key in run position i can touch the positive battery post and the car starts right up. I have also switch the relay with others in the box with same number. could you give me somemore feed back im at a loss. thanks Rich ps again this car sat in a garage for 4 yrs out of the weather and looks like new and only 68,800 miles on it
9 years 1 week ago #14293 by Chad
Cournoyer wrote: (is there supposed to be power at #30 with key in run )
Yes. #30 should have power all the time.
This suggests high resistance in the yel/lt blu solenoid wire. Check the connection at the relay and the solenoid. Possibly, corrosion inside the wire coating. To rule out a shorted solenoid , you could hook up a head light, or some other electrical load, in place of the solenoid.
9 years 1 week ago - 9 years 1 week ago #14294 by Chad
I should add that the voltage drop COULD be occurring ANYWHERE on the power feed,....From the Battery to the solenoid, including the relay, itself. Does the voltage at the 50amp fuse drop when cranking?
  • Cournoyer
9 years 1 week ago #14295 by Cournoyer
i did put a new connector on the starter wire down by the starter yellow with stripe and when i had the fuse tray upside down i saw no visual sign of corrosion on that yellow wire with stripe under relay #87 how can my solenoid be bad if i can jump it with a wire to that battery positive and she starts right up? if i pull out the relay can i jump 86 to 85 and 30 to 87 and try to start the car ? is there any way the pcm is involved with this problem even though it is at the end of the circuit on the control side? thanks Rich
  • Cournoyer
9 years 1 week ago #14296 by Cournoyer
i did not check if the voltage drops at the 50 am while cranking do i just pop the clear top off and touch positive lead to fuse through meter to ground i never tested a super fuse Rich
9 years 1 week ago - 9 years 1 week ago #14297 by Chad
Cournoyer wrote: how can my solenoid be bad if i can jump it with a wire to that battery positive and she starts right up?
Good point.:whistle: Lol
30 to 87, yes....86 to 85, NO!
Pin 44 of the PCM Should supply a ground to the relay. If it is, then the PCM is not the problem. A way to test everything else involved would be to ground pin 44 by back probing the PCM.... With the key in the start position and the gear selector in Park or Neutral, Pin 86 of the relay should have power. The computer grounds pin 85. The relay closes. At this point, you should have battery voltage on pins 86, 87, and 30. Pin 85 should have a ground....the starter should be cranking.
9 years 1 week ago #14298 by Chad
Cournoyer wrote: i did not check if the voltage drops at the 50 am while cranking do i just pop the clear top off and touch positive lead to fuse through meter to ground i never tested a super fuse Rich
You can do that, or pull the fuse and reconnect it with jumper wires.
  • Cournoyer
9 years 1 week ago #14302 by Cournoyer
should the car start if i do all that while grounding pin 44 at the pcm ? also i have tried to jump 30 to 87 and get no start at all
9 years 1 week ago #14305 by Chad
Yes. It should start. I mentioned grounding pin 44 only for informational purposes. I, really, don't think the PCM is the problem. You have a major voltage drop on the solenoid power feed. This is where we need to concentrate. To cut to the chase, if there is power at the 50 amp fuse and you pull the relay and jump 30 to 87, the starter should crank. End of story. However, your voltage is dropping from battery voltage to less than 1 volt. We need to find WHERE it is dropping.
9 years 1 week ago #14306 by Chad
This is, definitely, worth watching.
  • Cournoyer
9 years 1 week ago #14307 by Cournoyer
i agree i thought about bypassing the yellow wire with stripe to solenoid altogether ! using my 10 gauge jump wire . but you are telling me that the load drop could go all the way back to battery through the 50 amp fuse i will check voltage wile in start on that fuse. when i visually looked at # 87 pin under side that connector looked ok how do i pop those connectors out out the box to get a better look ? today i tried to probe the yellow wire right past the #87 underside while in start and i got low voltage i will try that again tomorrow i may have not had enough contact on the copper part of the wire.
Time to create page: 0.373 seconds
