2006 Lexus GS300
  • Onebadseed
  • Onebadseed's Avatar Topic Author
9 years 6 days ago - 9 years 6 days ago #14315 by Onebadseed
2006 Lexus GS300 was created by Onebadseed
I had a code for the cam and crank sensor on a 2006 Lexus GS 300 car won’t start change both cam and crank sensor now it will start once I wouldn’t start again i took to the mechanic shop they had it for one month call me back and said he cant figure it out they check all wire and compression so I pick it up took back home and remove spark plugs once again notice the passenger side had normal wear from when the car would start and I would hold the pedal down and have it run but driver side look new just wet. I just want try something to see what would happen so i remove driver plugs and disconnect maf sensor and attempted to start the car low and behold it started in stay running until I turn it off. I’m thinking No communication with ECU on driver-side. Need help please and thanks
Last edit: 9 years 6 days ago by Onebadseed.
9 years 6 days ago #14318 by steve
Replied by steve on topic 2006 Lexus GS300
Has the timing been checked?
9 years 6 days ago #14321 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 2006 Lexus GS300
I also would think timing I would say the cam-crank correlation needs to be checked on both banks.
Do these engines have a separate MAP sensor ? ISTR it is MAF engine.
  • Onebadseed
9 years 6 days ago #14325 by Onebadseed
Replied by Onebadseed on topic 2006 Lexus GS300
Timing as been check it was ok
  • Onebadseed
9 years 6 days ago #14326 by Onebadseed
Sorry I disconnected the mass airflow sensor not the map sensor
  • Onebadseed
9 years 4 days ago #14380 by Onebadseed
Do you think maybe its the cam phaser gone bad
Time to create page: 0.360 seconds
