p0420
  • jasdeep
  • jasdeep's Avatar Topic Author
8 years 11 months ago #14676 by jasdeep
p0420 was created by jasdeep
hi guys i have 2009 prius it has code p0420
i cant see any leaks or anything cleaned maf .
i have attached freeze frame data . Any suggestion and diag method are highly welcomed.
thanks
File Attachment:
File Name: LiveDTCPri...1-02.pdf
File Size:84 KB
8 years 11 months ago #14682 by cj1
Replied by cj1 on topic p0420
Low temp at cat output and 02 sensor high/low indicates cat not working properly.
The following user(s) said Thank You: jasdeep
8 years 11 months ago - 8 years 11 months ago #14684 by Chad
Replied by Chad on topic p0420
cj1 wrote: Low temp at cat output and 02 sensor high/low indicates cat not working properly.
+1
Last edit: 8 years 11 months ago by Chad.
8 years 11 months ago #14711 by Tyler
Replied by Tyler on topic p0420
Fuel trims look good, no exhaust leaks found, sensors appear reactive... Sounds like a bad cat. :-(
I'd suggest clearing the code and rechecking the catalyst monitor, if you haven't already. If you can reproduce the code, then it's probably cat time.
8 years 11 months ago #14719 by EricGoodrich
Replied by EricGoodrich on topic p0420
I have yet to encounter a false P0420.
8 years 11 months ago #14763 by bruce.oliver
Replied by bruce.oliver on topic p0420
I have fixed cat codes with new o2 sensors before. Not many, but a few. If you can look at mode6 data, if the cat is barely failing or it has old o2 sensors or if the o2 sensors are barely passing the monitor in mode6 data, then you can replace the o2s first. You are likely replacing them anyway when you replace the cat. Last one was a traverse, p0420, mode 6 showed the last cat monitor as passed, replaced the o2 sensors then the cat showed enough life to last a while longer. Doesnt always work, most times they just need a cat
