2009 Chevy Cobalt Manual 2.2 P080A
- ahill007ny
8 years 11 months ago #15049
by ahill007ny
2009 Chevy Cobalt Manual 2.2 P080A was created by ahill007ny
Hey guys I'm working on a 2009 Chevy Cobalt Manual 2.2 it's a No Crank No start and setting code P080A Clutch Position not learned. From what I read about the code when it sets you have to do a relearn with the scan tool or it will not Crank. I was using the OTC Encore and didn't see the option in the menus.. Is it available on other scanners like the Verus, Maxisys, or are you forced to use the Tech II? Thanks
- cheryl hartkorn
- Thank you received: 130
8 years 11 months ago #15050
by cheryl hartkorn
Replied by cheryl hartkorn on topic 2009 Chevy Cobalt Manual 2.2 P080A
im not sure. i know the snap on scanners have a brake pedal position relearn in the bcm. do you see a pid for the clutch switch in the ecm? wonder if it would start jumping the switch with a jumper wire.
- ahill007ny
8 years 11 months ago #15053
by ahill007ny
Replied by ahill007ny on topic 2009 Chevy Cobalt Manual 2.2 P080A
Yes under engine there are pids for the clutch, clutch pedal position learned position, clutch pedal position voltage, clutch percentage. When I apply the cutch all the way it's percentage goes to 70 %
- fudgie
- Thank you received: 4
8 years 11 months ago - 8 years 11 months ago #15075
by fudgie
Replied by fudgie on topic 2009 Chevy Cobalt Manual 2.2 P080A
Switch adjusted properly? Maybe see if you can push it further with your fingers.
Last edit: 8 years 11 months ago by fudgie.
