2009 Honda Civic Dx 1.8L no crank
  • Motorhead
  • Motorhead's Avatar Topic Author
8 years 11 months ago #15093 by Motorhead
2009 Honda Civic Dx 1.8L no crank was created by Motorhead
2009 Honda Civic Dx with a 1.8 L engine was driving normal, shut off, and upon return about a half hour later, car would not crank. Headlights burn bright, does not dim when trying to crank. Tried to put in neutral to see if it would crank, shifter would not move(shifter interlock) No dash warning lights, horn and brake lights work. I am suspecting a bad ignition switch, but don't want to be a parts changer. Is there any other checks I can do to test the ignition switch?
8 years 11 months ago #15096 by Chad
Replied by Chad on topic 2009 Honda Civic Dx 1.8L no crank
Check the 50 amp MULTI-FUSE 2 (Under hood fusebox, left side of engine compartment)
The following user(s) said Thank You: Motorhead
8 years 11 months ago #15105 by EricGoodrich
Replied by EricGoodrich on topic 2009 Honda Civic Dx 1.8L no crank
I wouldn't even begin to diagnose an electrical problem without a wiring diagram. It's like trying to drive somewhere you've never been without a road map. You should be able to look at a wiring diagram and narrow down the possibilities making your diagnostic process quick and accurate.
8 years 11 months ago #15142 by fudgie
Replied by fudgie on topic 2009 Honda Civic Dx 1.8L no crank
See if you have voltage at the skinny wire at the starter when switch is in start? Starter under intake behind engine.
