2004 Toyota camry 2.4l. Immobilizer issue?
  • johnathon.balderas
  • johnathon.balderas's Avatar Topic Author
  • Stay humble and thank God everyday for waking up.
8 years 11 months ago #15240 by johnathon.balderas
2004 Toyota camry 2.4l. Immobilizer issue? was created by johnathon.balderas
Diagnosing a no start. Getting ignition coil control but no injector control, is this an immobilizer strategy to disable fuel injectors only.? Any knowledge shared on these immobilizer systems would be appreciated. Thank you and God bless
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
8 years 11 months ago #15242 by cheryl hartkorn
Replied by cheryl hartkorn on topic 2004 Toyota camry 2.4l. Immobilizer issue?
have you done a system scan with a scanner yet? if not post the codes if it has any... something easier if you have a 2nd key might want to try that to
  • Ro-longo
  • Ro-longo's Avatar
  • North Salt Lake, Utah
8 years 11 months ago #15243 by Ro-longo
Replied by Ro-longo on topic 2004 Toyota camry 2.4l. Immobilizer issue?
Any theft light blinking on the dash?
8 years 11 months ago #15249 by johnathon.balderas
Replied by johnathon.balderas on topic 2004 Toyota camry 2.4l. Immobilizer issue?
The security light only blinks when the cars is locked. And the battery was disconnected for awhile. I however assumed there was no codes so I didn't check for codes. I initially thought the injector drivers were cooked because the check engine light doesn't come on what so ever and I thought the immobilizer disabled (no control) injectors and coils. Not just the injectors.
8 years 11 months ago #15267 by johnathon.balderas
All fuses are good. I'm getting power to the injectors just no control. Even the coils are firing
8 years 11 months ago #15278 by toyota1990s
Replied by toyota1990s on topic 2004 Toyota camry 2.4l. Immobilizer issue?
I had a similar issue with a '97 uk spec Rav4 when i had to renew the 100 amp ALT fuse because of a previous bodged repair! This led to a cranking no start just like yours. The vehicle had spark but no injection pulse. I solved my issue by trying the "Master" key and the Rav fired up again and was no more trouble. Might solve your problem. Steve
8 years 11 months ago #15282 by juergen.scholl
Replied by juergen.scholl on topic 2004 Toyota camry 2.4l. Immobilizer issue?
1 - the immobilizer does cut injection pulse
Does the vehicle start with an alternative fuel source sprayed into the manifold? Does the ecu communicate, do you have 5V ref?
Check power and grounds to ecu and do a sistem scan. "Assuming" can (and will) lead you astray.....
8 years 11 months ago #15359 by johnathon.balderas
Scan tool does communicate. Nothing seems a miss except no injector control
8 years 11 months ago - 8 years 11 months ago #15371 by juergen.scholl
Check for fuses that should NOT be there according to the fuse box diagram. On several Toyota cars fuses in places not designed for them will cause exactly your symptom.
Last edit: 8 years 11 months ago by juergen.scholl.
