Crank no start 1994 ford f150
  • TransAmpunk
  • TransAmpunk's Avatar Topic Author
8 years 11 months ago #15417 by TransAmpunk
Crank no start 1994 ford f150 was created by TransAmpunk
Okay so its a 4.9 liter. Same deal as the one in your "but kicked video". Anywho no fuel pressure and only sparks when spout is unpluged ( jumper). Need help . my big thin is that there is no prime from the pump but when key is turned indonhere the relay click. ?
8 years 11 months ago - 8 years 11 months ago #15455 by Chad
Replied by Chad on topic Crank no start 1994 ford f150
TransAmpunk wrote: only sparks when spout is unpluged ( jumper). Need help . my big thin is that there is no prime from the pump but when key is turned indonhere the relay click. ?
My guess is that you have a bad PCM. Check your powers and grounds. Check the IDM/START circuit. Unplugging the SPOUT takes the computer's influence out of the equation. The computer is not needed to create spark. A PIP signal is all the ICM needs, besides power and ground.
Last edit: 8 years 11 months ago by Chad.
