04 silverado
- Tireman25
Engine Load = 9.412 %
Engine Coolant Temperature = 201.2 °F
Fuel Trim Bank 1 Short Term = 6.25 %
Fuel Trim Bank 1 Long Term = 25 %
Fuel Trim Bank 2 Short Term = -2.344 %
Fuel Trim Bank 2 Long Term = 23.438 %
Intake Manifold Pressure = 6.382 psi
Engine RPM = 1,362.5 rpm
Speed (OBD) = 46.603 mph
Mass Air Flow Rate = 165.401 cfm
Throttle Position(Manifold) = 21.961 %
- cheryl hartkorn
- Thank you received: 130
- Tireman25
- Tireman25
I still have a hard time with the relationship between manifold pressure and barometric pressure and manifold absolute pressure.
Noah wrote: Oh, and forgive my ignorance, but could someone please explain the 6lbs of pressure in the intake during cruise?
I was thinking the same thing. Is this based on 14.7 psi atmospheric pressure at sea level?
Noah wrote: I still have a hard time with the relationship between manifold pressure and barometric pressure and manifold absolute pressure.
To my understanding, barometric pressure is atmospheric pressure, 29.92 inches of mercury (14.7 psi) at sea level . Manifold pressure is the pressure inside the manifold. Absolute pressure is the difference between the two.
Normally, we think of atmospheric pressure as zero pressure. Anything above 14.7 psi (29.92 inHg) @ sea level is pressure. Any thing below 14.7 psi ( 29.92 inHg) @ sea level is a vacuum. Looking at it this way, with 6psi inside the manifold and 14.7 (29.92 inHg) on the outside. The 6 psi (?? inHg) would be a vacuum.
This is, merely, my own reasoning and may, very well, be wrong.
