2001 GMC YUKON 5.3 secondary air sytem monitor not complete
  • jaivs26
  • jaivs26's Avatar Topic Author
8 years 10 months ago #15592 by jaivs26
Hi Mates!
I'm working on a 01 yukon with 213K and the 5.3L , i'm trying to complete the drive cycle for the smog inspection but i'm having hard time completing the secondary air system monitor..
i replaced the fuel level sensor and thermostat and cleared the codes but i been driving the truck for 30 miles in total i'm thinking to change both upper o2 sensors to see if that cures the problem but i want to test them first
Today just replaced the check valves on the exhaust, check the vacuum from the intake to the solenoid and from the solenoid to the other valve
the pump is working and blows lots of air.
on a cold start the air pump turns on for 30 seconds and then turns off,
i'm trying to follow this procedure the best i can
1.-Cold Start. In order to be classified as a cold start the engine coolant temperature must be below 50°C (122°F) and within 6°C (11°F) of the ambient air temperature at startup. Do not leave the key on prior to the cold start or the heated oxygen sensor diagnostic may not run.
2.-Idle. The engine must be run for two and a half minutes with the air conditioner on and rear defroster on. The more electrical load you can apply the better. This will test the O2 heater, Passive Air, Purge "No Flow", Misfire and if closed loop is achieved, Fuel Trim.
3.-Accelerate. Turn off the air conditioner and all the other loads and apply half throttle until 88km/hr (55mph) is reached. During this time the Misfire, Fuel Trim, and Purge Flow diagnostics will be performed.
4.-Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for 3 minutes. During this time the O2 response, air Intrusive, EGR, Purge, Misfire, and Fuel Trim diagnostics will be performed.
5.-Decelerate. Let off the accelerator pedal. Do not shift, touch the brake or clutch. It is important to let the vehicle coast along gradually slowing down to 32km/hr (20 mph). During this time the EGR, Purge and Fuel Trim diagnostics will be performed.
6.-Accelerate. Accelerate at 3/4 throttle until 88-96 km/hr (55-60mph). This will perform the same diagnostics as in step 3.
7.-Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for five minutes. During this time, in addition to the diagnostics performed in step 4, the catalyst monitor diagnostics will be performed. If the catalyst is marginal or the battery has been disconnected, it may take 5 complete driving cycles to determine the state of the catalyst.
8.-Decelerate. This will perform the same diagnostics as in step 5. Again, don't press the clutch or brakes or shift gears.
After i complete all the steps i let it cool down for a least 3 hours and monitor the coolant before i drive it again.
any advise before i replace the o2 ?
