06' commander4.7 po507
1 year 10 months ago #73378 by bobrl
06' commander4.7 po507 was created by bobrl
I have 06' commander with 4.7 and i keep getting a po507 code! I have smoked the system and repaired all vacuum leaks i can find!! Checked the air box, filter, hose connection and all seems fine. Aic is operating as it should, snap on Verus pro shows 0 % aic at idle and it will only control the idle test down to 900 rpm ! I watched your video on this issues and you said most always a vacuum leak, but you then saidit could be other things as well, please say what the other thing may be!!  Thanks, great Fan of your work!!!! Bob in Il.
1 year 10 months ago #73711 by Noah
Replied by Noah on topic 06' commander4.7 po507
IAC command to zero and still having high idle typically is from a vacuum leak.
I know you said the scan tool test won't drop idle below 900rpm, where does the engine idle once it's warmed up?
Is there data PIDs to compare actual rpm vs desired rpm?
Some things that come to mind are a sticking IAC valve not actually closing all the way, naturally a vacuum leak, possibly an EGR valve issue.
Time to create page: 0.254 seconds
