99 Toyota 4 Runner no spark
- Bigfoote13
- Thank you received: 2
8 years 10 months ago #15810
by Bigfoote13
99 Toyota 4 Runner no spark was created by Bigfoote13
Greetings. On this Toyota I have no spark. I get an RPM signal on my scan tool but no signal to the RPM gauge and cam sensor continuity checks out okay. I had spark once for a little bit but then no longer. I have 12 volts to the coils but don't seem to get any signal to the crank sensor. Is the crank sensor connector on these motors on top of the motor behind the timing belt cover and goes down in the front behind the timing belt to the crankshaft sensor?
8 years 10 months ago #15824
Replied by Chad on topic 99 Toyota 4 Runner no spark
What engine?
- Bigfoote13
8 years 10 months ago #15825
by Bigfoote13
Replied by Bigfoote13 on topic 99 Toyota 4 Runner no spark
3.4 sorry
- arbez
- Thank you received: 53
8 years 10 months ago #15829
by arbez
Replied by arbez on topic 99 Toyota 4 Runner no spark
Waste spark system with 2 Wire coils. You should have power to the coils with the key on (same color wires). Different color wires controlled by igniter, controlled by PCM. Should be able to check with a test light.
Let us know what your missing & we will go from there.
Do you have a test light, multi meter or scope? Just so we know how to advise you.
- Bigfoote13
8 years 10 months ago #15833
by Bigfoote13
Yes I do all of the above. And the igniters in the coils isn't it? No that would be in the PCM? Thank you for your advice.
- arbez
8 years 10 months ago #15835
by arbez
Your response confuses me.
Is your engine the 5VZ-FE or the 3RZ-FE? I didn't realize the wiring diagram covered 2 different systems.
- Bigfoote13
8 years 10 months ago #15837
by Bigfoote13
5VZ-FE
- arbez
8 years 10 months ago #15838
by arbez
So you have 3, 2-wire coils?
