1993 Ford F-150 5.0 liter v8 flub fix question
- popoften
- Thank you received: 22
8 years 10 months ago #15902
by popoften
1993 Ford F-150 5.0 liter v8 flub fix question was created by popoften
Several years ago when bolting the drivers side exhaust manifold back on, I accidentally put one of the long bolts in a shallow hole and of course proceeded to punch through into the water jacket. I have had a slow coolant leak past that bolt the whole time since then.
I now need to replace that exhaust manifold because it has developed a crack.
My question is, is there any kind of sealer I can put into that damaged bolt hole to stop the chronic slow coolant leak I caused?
- Ben
- Thank you received: 215
8 years 10 months ago #16078
by Ben
Replied by Ben on topic Re:1993 Ford F-150 5.0 liter v8 flub fix question
Might be too late I see you posted this a while ago but high temp silicon would be my first choice
- arbez
- Thank you received: 53
8 years 10 months ago #16085
by arbez
Replied by arbez on topic Re:1993 Ford F-150 5.0 liter v8 flub fix question
Sounds like the only real fix would be to have the cylinder head repaired, or replace it. You will never be able to fully count on it's reliability. Something like that will turn around & bite on the backside when you need it most.
- popoften
8 years 10 months ago - 8 years 10 months ago #16086
by popoften
Replied by popoften on topic Re:1993 Ford F-150 5.0 liter v8 flub fix question
I did already install he manifold a few days ago, and interestingly enough, the anti-seize I put on the bolt seems to be sealing it for now. I don’t think that will last, but if it starts to leak, it will be easy enough to remove the bolt and try some hi temp silicone.
Yes, it probably would be best to remove the head and repair, but given the age of the truck I think I’ll go with the bandaids.
Thanks guys!
Thanks guys!
Last edit: 8 years 10 months ago by popoften.
8 years 10 months ago - 8 years 10 months ago #16101
Replied by Noah on topic Re:1993 Ford F-150 5.0 liter v8 flub fix question
I've seen guys drill into the water jacket extracting broken manifold bolts. While I certainly agree that removing or ultimately replacing the head is the real fix here, some silicone seems to have saved the the day more than once.
I think I started to watch an Eric The Car Guy video where he penetrated the jacket during a manifold repair. I either didn't finish watching, or just don't remember what he did to fix it.
Edit:. Found it, JB Weld
Last edit: 8 years 10 months ago by Noah.
Time to create page: 0.354 seconds
