06' commander 4.7. More issues
1 year 10 months ago #74098 by bobrl
06' commander 4.7. More issues was created by bobrl
I am still trying to fix the po507, cant find any more vacuum leaks and all items pertaining to this code have been tested , cleaned and still not corrected!! Now a new issues has arised!! When i was checking codes on my Verus Pro , like thirty codes popped up!!!!!! Service suspension was on the dash, things like air bag igniter, door lock  and on !!!!!! Now i hear the TIPM is a issue with this jeep. Does it ever end?  Thanks.
1 year 10 months ago #74172 by Lupe
Replied by Lupe on topic 06' commander 4.7. More issues
make sure you have a good battary , good grounds , also reset your ecm or you might disconnect battary over 4 hrs
1 year 10 months ago #77353 by bobrl
Replied by bobrl on topic 06' commander 4.7. More issues
I fixed the po507 code !!!! It was the throttle plate set screw !! Someone before me must have turned screw out to compensate for issues when engine was crapping out!!! Now with new rebuilt 4.7 it was idling too high!!! Found it when i was smoke testing for vacuum leaks!! Thought that there was a lot of smoke coming around plate!!!! Took a piece of cardboard and cut out the IAC opening , and covered the rest of the throtle while idling and wow!!!! It idled right down to 600 rpms and everything worked as it should!!!!! Turned the set screw in about 3 or four turns and it is resolved!!!!!!!! Thanks
The following user(s) said Thank You: Noah, Lupe
