Range Rover 2002 L322 V8 4.4L engine
  • naros812000
  • naros812000's Avatar Topic Author
8 years 10 months ago #16102 by naros812000
Range Rover 2002 L322 V8 4.4L engine was created by naros812000
Dears,
I am currently diagnosing L322 range rover v8 4.4L engine. The car suffers an imaginable heavy hesistation with no accelerator response. When I clean the codes and keep my foot pressed on the accelerator, the car rpm increase to 3000rmp no more. When I switched off and back on, no more response.
Here are the codes
098 tank venting valve
134 Loam function, lower stop, throttle actuator
140 Activation Map Cooling
I used snapOn Verus to diagnose TPS and Pedal sensor. Everything worked as suggested.
Any suggestion
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
8 years 10 months ago - 8 years 10 months ago #16119 by Dylan
Replied by Dylan on topic Range Rover 2002 L322 V8 4.4L engine
Welcome to the forum!
Moving your thread to the repair section so it gets the proper attention.
Last edit: 8 years 10 months ago by Dylan.
  • chief eaglebear
  • chief eaglebear's Avatar
8 years 10 months ago - 8 years 10 months ago #16214 by chief eaglebear
Replied by chief eaglebear on topic Range Rover 2002 L322 V8 4.4L engine
hi not too experienced but I would address the tps issue first it sounds like vehicle is in limp home mode because its not getting some inputs like tps the map issue might be caused by the other problems but I would try to find direction by looking at inputs in question
Last edit: 8 years 10 months ago by chief eaglebear.
Time to create page: 0.266 seconds
