2004 Lincoln navigator missfire cylinder #8 under load 40 mph... 1900rpm
  • Rabbit
  • Rabbit's Avatar Topic Author
8 years 9 months ago #16603 by Rabbit
i found water on coil #8 i swap the coil problem continues .... i resently replaced spark plugs..... problem started after a trip to a car wash.... it misfires more under load... 02 sensor drop lean whe misfire happens.... the feels thant it has no power to accelerate..it ..shakes
P0308
p0174
any help thank you:whistle: :)
8 years 9 months ago #16607 by arbez
Your double posted on this. I'm sure someone will delete one of them.
P0308 - Did you dry out the water in the spark plug tube? Do you have spark from the #8 coil? Coil & injector control? Tell us what your missing & we can guide you further/farther.
P0174 - Possible vacuum leak, maybe an intake gasket?
O2 sensor is normal when the misfire isn't acting up?
You have to get the misfire fixed first.
  • Rabbit
8 years 9 months ago #16608 by Rabbit
yes i dried the #8 tube coil...
8 years 9 months ago #16610 by arbez
Rabbit wrote: yes i dried the #8 tube coil...
OK...
Do you have spark from that coil?
Coil control?
Injector control?
Let us know & we will try to help
  • Rabbit
8 years 9 months ago #16621 by Rabbit
i just checked for spark.... i found coolant in the #8 coil ...it was not water.... i guess it needs a head gasket.... thanks so much for the help
8 years 9 months ago - 8 years 9 months ago #16623 by Tyler
Rabbit wrote: i just checked for spark.... i found coolant in the #8 coil ...it was not water.... i guess it needs a head gasket.... thanks so much for the help
Coolant in the spark plug tube? What's the 8th digit of the VIN? I ask because if it uses a plastic intake plenum, then it's WAY more likely that the intake itself is cracked and leaking coolant into the plug tubes. Happens all the time. ;)
Last edit: 8 years 9 months ago by Tyler.
8 years 9 months ago #16624 by arbez
Agreed. Intake gasket or the intake itself. Head gasket couldn't get into the spark plug tube. Only other option would be a weirdly cracked cylinder head. You should be able to clean up the area & pressure test the cooling system. Problem should be obvious.
  • Rabbit
8 years 9 months ago #16630 by Rabbit
vin:last eight digits 4LJ21422
  • Rabbit
8 years 9 months ago #16631 by Rabbit
the 8th digit the vin iis "R"
