No start
  • FastFreddy1970
  • FastFreddy1970's Avatar Topic Author
8 years 9 months ago - 8 years 9 months ago #16629 by FastFreddy1970
No start was created by FastFreddy1970
2003 f250 5.4 automatic
No rpm, no injector pulse, no spark. Have power but no ground.
Tested crank sensor, did not have a ac current pattern. Replace crank sensor still no start, same issues but now with an ac pattern. Was checked at sensor and ecm both times with both sensors. Checked for 5 volt ref on other sensors all ok. No codes in ecm any suggestions?
Last edit: 8 years 9 months ago by FastFreddy1970. Reason: Added info
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
8 years 9 months ago #16636 by cheryl hartkorn
Replied by cheryl hartkorn on topic No start
sounds like a pcm issue if you have the ac sine wave at the pcm and still no rpm. what about cam sensor signals??
8 years 9 months ago #16649 by arbez
Replied by arbez on topic No start
I second the computer theory.
I have done several E/F series computers around that year. Check powers, grounds, cam & crank signals at the PCM. If all is OK, put a computer in it.
Here are some diagrams to refer to:
www.revbase.com/BBBMotor/Wd/DownloadPdf?id=38315
www.revbase.com/BBBMotor/Wd/DownloadPdf?id=38316
www.revbase.com/BBBMotor/Wd/DownloadPdf?id=38318
Let us know what you find.
