Engine code p0014 on a ecotec 2.4
  • Wilson garcia l
  • Wilson garcia l's Avatar Topic Author
8 years 9 months ago #16718 by Wilson garcia l
Engine code p0014 on a ecotec 2.4 was created by Wilson garcia l
Hello mr danner I 've got a problem with a 2.4 equinox ecotec engine I had the p0014 exhaust actuator valve and I replaced it but the same code came back as I drive for ten minutes the two pins connector has the steady ground and the bias voltage the question is how can I substitute the valve to probe if the computer is good or not the signal for that actuator is always blinking tested with test light and you can see it in the scan tool as well percentage goes back and forth thanks for your replay
8 years 9 months ago #16727 by Tyler
Replied by Tyler on topic Engine code p0014 on a ecotec 2.4
FYI Wilson, I moved this to the Repair section. ;-) For our info, what's the year/make/model of the vehicle you're working on?
Because you've been testing for bias voltage, I figure you've seen this video?
If you've installed a test light in place of the exhaust solenoid, and saw it blinking, then I'd say you've proven out the wiring and PCM. Plus, the electrical monitor for the solenoid circuits is pretty darn good, IMO. At this point, I'd be more concerned about a genuine timing issue. According to my info, the PCM has to see a difference of more than six degrees between the desired CMP angle and the actual CMP angle for more than 13.5 seconds. In other words, the PCM commanded an angle change and didn't get it.
Can you post the scan data of your test drive? I'd be interested to see what the Desired CMP and Actual CMP do. This may be Captain Obvious of me to ask, but how's the oil level/condition?
Time to create page: 0.242 seconds
