Holding down gas pedal when starting vehicle with electronic throttle bodies
- Ian14
8 years 9 months ago #16756
by Ian14
Holding down gas pedal when starting vehicle with electronic throttle bodies was created by Ian14
Can u share your ideas on this subject, are we indeed weakimg the mixture due to the throttle valve being open, or does the pcm alter the injector pulse width due to change in map/maf. Many thanks ian
- Can Bus
- Thank you received: 2
8 years 9 months ago #16765
by Can Bus
There Is No Such Thing As A Stupid Question, If It's Sincere. Better To Ask And Risk Appearing Stupid Than To Continue On Your Own Ignorant Way And Make A Stupid Mistake. Author Confidential/Unknown
Replied by Can Bus on topic Holding down gas pedal when starting vehicle with electronic throttle bodies
On some vehicles in "clear flood mode" the pcm will severly lean the mixture.
- Ian14
8 years 9 months ago #16784
by Ian14
Replied by Ian14 on topic Holding down gas pedal when starting vehicle with electronic throttle bodies
Thanks for the reply, on some vehicles gas pedal fully pressed pcm shuts off injectors, but what if you only have the pedal half way down? Any thoughts. Thanks ian
- juergen.scholl
- Active partschanger
- Thank you received: 462
8 years 9 months ago #16785
by juergen.scholl
Replied by juergen.scholl on topic Holding down gas pedal when starting vehicle with electronic throttle bodies
Most engine controllers with clear flood mode will enter into thiis mode with tps > 80%. You could check tps and injector pulse width PIDs on the scantool in a particular car ànd see the switching criteria /value.
- Ian14
8 years 9 months ago #16805
by Ian14
Thanks for the replies, I will over the next few weeks test various vehicles to see what the pcm does to injector pulse with throttle quarter, half and fully open and record my findings many thanks for the replies
