shake and shutter
- andych1
8 years 9 months ago - 8 years 9 months ago #16823
by andych1
shake and shutter was created by andych1
95 olds 98 ser2 226xxx mi. had condition of engine dying on hwy. to start I would need to hold down accelerator 1/4. I found open loop in tps with continuity test. Also replaced maf cause I was little rough while cleaning it. Starts and revs fine. Once down road 5 to 7 miles I have intermitten shaking or shutter. It will almost die but continues on. it did die once which required using accel to start. Engine light came on only once for about 15 sec then went off after another shutter. Both tps and maf have 5v signal and ground. Any questions or suggestions that will point a direction? thx.
Last edit: 8 years 9 months ago by andych1.
- andych1
8 years 9 months ago #16962
by andych1
Replied by andych1 on topic shake and shutter
took it to shop codes were o2 ,cam, lock up conv., and overdrive. Im really thinking it could be lock up clutch causing it to almost die. Picked it up today and experienced crank no start first 2 tries.
- Can Bus
- Thank you received: 2
8 years 9 months ago #16964
by Can Bus
There Is No Such Thing As A Stupid Question, If It's Sincere. Better To Ask And Risk Appearing Stupid Than To Continue On Your Own Ignorant Way And Make A Stupid Mistake. Author Confidential/Unknown
Replied by Can Bus on topic shake and shutter
Does it act like it wants to stall from park to drive? Just sounds like torque converter shudder. However a dirty MAF sensor can cause shifting problems. Did the problem happen before or after you replaced the MAF sensor? Just because the MAF is new doesnt mean it works.
- andych1
8 years 9 months ago - 8 years 9 months ago #16966
by andych1
Does not stall park to drive. Happens at steady accel on hwy. It almost dies in OD or drive. It went this far on Lubeguard or Mr fix it tranny. its a t440
- Tutti57
- Thank you received: 254
8 years 9 months ago #16968
by Tutti57
Replied by Tutti57 on topic Re:shake and shutter
What are the fuel trim numbers?
- andych1
8 years 9 months ago #16970
by andych1
Replied by andych1 on topic Re:shake and shutter
don't have those #s. Only have multimeter
- andych1
8 years 9 months ago #17248
by andych1
took it to transmission shop. found to be icm. Had intermitten fire problem. Thx for ur input.
