Mitsubishi galant.year 1996
  • cyrus.nk
  • cyrus.nk's Avatar Topic Author
10 years 1 month ago #1773 by cyrus.nk
Mitsubishi galant.year 1996 was created by cyrus.nk
working on GDI system is horrible!!!stress!!!am working on tis car with not start condition.the only problem i get is no injections control at all.is it possible to check injector controll signal from injector drive module with a test light?am getting 5 volts on one wire and the other wire 300 mv and i think 5 vlts is bias voltage coz i get it connect unplugged only.
10 years 1 month ago #1780 by matt.white
Replied by matt.white on topic Mitsubishi galant.year 1996
I'd suspect not. I'm still new to GDI but I'm quite certain there's an opening voltage go up to 80v then a Pwm hold signal to keep it open.
Either way yours is definitely too low.
You certain it's a 1996 with GDI?
10 years 1 month ago #1782 by 1mouse3
Replied by 1mouse3 on topic Mitsubishi galant.year 1996
a test light can be used for test of control
  • cyrus.nk
10 years 1 month ago #1784 by cyrus.nk
Replied by cyrus.nk on topic Mitsubishi galant.year 1996
Yes?but still this system comes with newer io and gallant.
  • cyrus.nk
10 years 1 month ago #1786 by cyrus.nk
Ok thanks.my test light flashes on 5 vlts wire connected to b-
10 years 1 month ago #1787 by 1mouse3
which engine do you got so I can look up a diagram
  • cyrus.nk
10 years 1 month ago #1788 by cyrus.nk
4g93
10 years 1 month ago - 10 years 1 month ago #1789 by 1mouse3
not able to get any diagrams on this but being a gdi you should have fuel pressure sensor. Do this pull your fuel pump fuse and crank your engine, at run what are the readings of this sensor. With the fuse back in and key off then to run what is the readings. Now test when cranking to see what you got as a reading
Last edit: 10 years 1 month ago by 1mouse3.
10 years 1 month ago #2057 by Caritech
Replied by Caritech on topic Mitsubishi galant.year 1996
Sorry now seeing this one, hope I can still help. I have experience dealing with the Gdi's and should have diagram to help.
With KOEO, on a working 4g93 gdi I got over 5V but I wouldn't be too concerned. A 4g13 gdi I'm working on now has 3.9V. Treat it like any other no start, look for what you're missing. You have spark? Tried starter fluid?
File Attachment:
File Name: Carismagdi.pdf
File Size:1,816 KB
  • cyrus.nk
10 years 1 month ago #2060 by cyrus.nk
Sparks are there.only injection problem.how can injection control without scope?
10 years 1 month ago #2061 by Caritech
On the 4g13 all the pins flickered on the test light to battery (+ve). Is it starting with starter fluid?
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
10 years 1 month ago - 10 years 1 month ago #2063 by Dylan
Replied by Dylan on topic Mitsubishi galant.year 1996
Hey Cyrus,
Did you check these videos on GDI? You're a premium member right?
Great classroom lecture from Paul on the basics of this. You can also follow along in your book.
Also check out this case study...
Part 1
Part 2
Part 3
Last edit: 10 years 1 month ago by Dylan.
10 years 1 month ago #2069 by Caritech
Honestly GDI isn't that bad just different. I think I saw you got flicker on a test light. I got that on the 4g13 and it's starting. 5V feed shouldn't be a concern, a fully operational 4g93 gdi had about that. Still need to know if throttle cleaner etc starting it. Most time with the gdi's here it's been fuel pumps, the injectors usually can take a beating. You have scan tool data? I'm sure I can help but need some more info.
Btw did the file I attached work? That's basically the Mitsubishi GDI setup.
