2010 ford misfire 2.5L
- keith
- cheryl hartkorn
- Thank you received: 130
www.scannerdanner.com/forum/diagnostic-t...ative-flow-test.html
For our info, is this a dead misfire, or does it only show up under certain conditions? Just based on my past experience with these engines, I'd suggest revisiting the relative compression test, as I've seen several with burned/leaking exhaust valves.
I'd also be interested to see the scope capture of the coil current ramps, especially #2. The three spikes is typical of the multi-strike strategy Ford uses at idle, but one spike is unusual.
- keith
- keith
I kinda doubt a faulty O2? If that were the case, I think you'd have had misfires on all cylinders and/or fuel trim codes. Plus, I believe this year of Escape uses an air/fuel ratio sensor instead of a conventional O2. So, your fixed reading from the upstream sensor is likely normal. Plus, your short term fuel trim hanging around 3% indicates that the sensor is probably alive/working.
- keith
- Ben
- Thank you received: 215
- ShawnRoberts81
