2008 Audi Q7 crank no start
1 year 10 months ago #76458 by WesD
2008 Audi Q7 crank no start was created by WesD
2008  Audi Q7 cranks but no start, although it did once after about an hour of trying. Only ran for about 5 minutes then died again, Using an Autel ultra for code reading and diagnosing, All codes were due to low voltage so I charged the battery and cleared codes. The issue i seem to be having is no ground signal from the ECM to the engine control relay, relay is not switching so no power to those fuses. External grounds into the ecm check out good using a power probe, Tried new ecm and same result, although i seem to be having an issue programming the new ecm to the car I expected at least to get a different result in the ground signal issue, but no luck so far. Any help or ideas would be greatly appreciated.
1 year 10 months ago #76647 by Tyler
Replied by Tyler on topic 2008 Audi Q7 crank no start
Will the engine start if you provide a ground to the control side of the engine control relay?
1 year 10 months ago #76653 by WesD
Replied by WesD on topic 2008 Audi Q7 crank no start
NO, the relay will trip but still the engine won't start. my sister drove it to the store and came out to this.
