03 Chevy impala 3.4 airbag light on
- Themechanic2388
8 years 8 months ago #17648
by Themechanic2388
03 Chevy impala 3.4 airbag light on was created by Themechanic2388
Ok I have a 03 chevy impala 3.4 with airbag light on checked codes erased all and just stayed with B1000 ecu malfunction and I can't get the air bag light off I don't no what to do from their now ... Need help !!!
- kostelectronics
- Thank you received: 7
8 years 8 months ago #17649
by kostelectronics
Replied by kostelectronics on topic 03 Chevy impala 3.4 airbag light on
You Need a new Airbag-Control Unit. This is a internal fault of your Airbag-Controller. Maybe you can try to reflash the Firmware, but this is not so easy...you Need a EEPROM-Programmer for this and a dump-file with a good Firmware.
BR Matthias
BR Matthias
- jacobnbr1
- Thank you received: 4
8 years 8 months ago #17653
by jacobnbr1
Replied by jacobnbr1 on topic 03 Chevy impala 3.4 airbag light on
I will also agree that the airbag module needs replaced. I wouldn't mess around with any reflash or eeprom stuff but go to a salvage yard and get a used one. After installing it, you need a scan tool to setup the used module but its easy and the scan tool does all the work. I believe most all snapon scanners can this and the function is in the bcm listed as "setup new SDM"
- Themechanic2388
8 years 8 months ago #17662
by Themechanic2388
Replied by Themechanic2388 on topic 03 Chevy impala 3.4 airbag light on
Ok so is that the sdm or the airbag in the steering wheel thanks so much .
- Themechanic2388
8 years 8 months ago #17663
by Themechanic2388
Ok. It's the small control module boottom of passanger side. Thank you. Very much
