2001 buick lesabre nt starting.
- Stoney Burke
8 years 8 months ago #17698
by Stoney Burke
2001 buick lesabre nt starting. was created by Stoney Burke
Hey Paul Danner, I have a question for you. I had a 2001 buick lesabre 3800 series that would not run, checked for the basics ( fuel, spark). I had no spark on the coil packs so I removed them and tested the ignition module with a test light and all drivers were firing so I re-installed the coil packs and found the middle coil pack showing good spark but the two on the ends with no spark and it still would not start, but if I pulled the plug wires off of the middle coil pack that was firing the car would start up and run but when re-installing the plug wires on the middle coil pack the car would shut off. So I switched the coil packs around( now all coils are firing and the car runs). What could have caused this problem? I'm confused.
- Doc n2mx
- Thank you received: 10
8 years 8 months ago #17706
by Doc n2mx
Replied by Doc n2mx on topic 2001 buick lesabre nt starting.
Hi,
I think that this car was sitting for a while, am I correct in my thoughts?
If So I would suspect that the contacts on the bottom of the coils were a bit crusty and thus making a bad connection. By you moving the coils you cleaned the contacts and by this action you have spark once more..
This is just my thought as I have had many issues with bad contacts. Normally you can clean them just by removing the two parts and replacing them. This is pretty common in computers.
Good luck
Doc
Good luck
Doc
- Stoney Burke
8 years 8 months ago #17708
by Stoney Burke
Replied by Stoney Burke on topic 2001 buick lesabre nt starting.
Well if I switch the coils back to their original positions it will not start.
- arbez
- Thank you received: 53
8 years 8 months ago #17709
by arbez
Replied by arbez on topic 2001 buick lesabre n0t starting.
I would unplug the coils, 1x1 & see what one allows it to start. Probably the middle one is bad, as stated in your original post. Shorted internally, I suspect. Moving them around may have have jostled something back into place. Inspect the connections & replace the suspected coil. All you can do with the amount of information & tool limitations that we seem to have. Let us know.
