2008 Subaru Impreza WRX 2.5 crank no start
- RailynsDada7622
1 year 10 months ago #77511
by RailynsDada7622
2008 Subaru Impreza WRX 2.5 crank no start was created by RailynsDada7622
So I had a customer bring me his ‘08 Impreza WRX after he was on a highway trip when it died. Said he was doing about 80 mph and it shut down on him. Cranks and bucks wanting to start but just won’t finish the job. I have spark, fuel, CKP sensor has signal and but CMP only has signal at initial turn of the key and then it loses its signal. All confirmed via scan tool. No tach on the dash but st reads 140 rpm. Any suggestions would be very much appreciated. Thanks guys and gals I’m sure
- Monde
- Thank you received: 43
1 year 10 months ago #77514
by Monde
Replied by Monde on topic 2008 Subaru Impreza WRX 2.5 crank no start
Are you maintaining power and ground when you lose the signal?
You are supposed to have 2 cam sensors according the the wiring diagram that I am using. Are they both acting up? Do you have good signal wire integrity?
The following user(s) said Thank You: RailynsDada7622
- RailynsDada7622
1 year 10 months ago #77515
by RailynsDada7622
Replied by RailynsDada7622 on topic 2008 Subaru Impreza WRX 2.5 crank no start
Agreed I should have two cam sensors scan to only shows crankshaft and one cam sensor. As far as I know Power and ground is fine. As far as I can tell rather, it’s just weird how the signal drops off after about two turns of the engine. Initially, I was thinking no compression possible cylinder dead but multiple videos. I’ve watched people had similar issues when cranking the car sound the same just sounds hollow like a toy car. No I tried to assume as little as possible.
- Monde
1 year 9 months ago #77768
by Monde
You can go to the sensors and check them. If you have good spark and injection pulse, the inputs are probably fine. Are you losing spark and injection pulse with the cam signal loss? Did you check compression and timing.
1 year 9 months ago #77771
Replied by Noah on topic 2008 Subaru Impreza WRX 2.5 crank no start
That's what I was thinking alsoDid you check compression and timing?
