Cam sensor problem
- sam12301
Its a 3 wire cam sensor iv tested the ground and thats ok iv tested the power feed which reads 5v and then its the signal wire im unsure of. It reads 5v with KOER and sensor disconnected then with the sensor connected it reads around 2.3v to 2.7v. I dont have a scope but i took the cam sensor out and i had it connected then i put a socket up to the end of the cam sensor to see if the voltage pulled to 0v and it did. But as a side note whenever i get the cam sensor DTC i seem to get a few other DCTs in the brake system and the centeral electrics system and immobilizer system all say ECU disbaled or no signal.
Based on all that im unsure if its a faulty ECU or not.
- Ben
- Thank you received: 215
- sam12301
- Ben
- Ben
- sam12301
- Ben
- sam12301
- Ben
- sam12301
- Tutti57
- Thank you received: 254
- Ben
- sam12301
- sam12301
- sam12301
- Shooter
I am new to the forum but an avid follower of Paul and his you tube videos.
I am a Certified Bosch Mastertech in the UK so more familiar with the European and Asian vehicles.
Back to your VW Fox.
From my experience P0340 is set when there is no signal from the CMP and P0341 is set when there is a signal but the PCM does not like it - timing etc.....
You could prove this by disconnecting your CMP or cutting the Signal wire with a view to promoting changes in the DTC's you get.
If that is 0-5v Hall Effect Sensor then it is no surprise that you are reading 2.5v with a DMM - It is taking an average ?? !! Furthermore, is that 2.5v backprobed at the PCM where the signal needs to be ?? or at the CMP Sensor ?
If you let me have the Year and Engine Code I will look up some data that may help you.
However, if the timing pins up ok then I do not see how you can proceed with this diagnosis without a good oscilloscope ! ?
- ScannerDanner
- Administrator
- Thank you received: 500
With the key on and cam sensor unplugged, what does the signal wire read? First, at the sensor and if it is only 2.x volts at the sensor, please measure the same wire at the PCM and compare.
Don't be a parts changer!
- sam12301
- sam12301
- sam12301
I tested the resistance of the singal and power wires from piercing each wire at the sensor and piercing the wires at the ecu and the resistance for both the signal and power was a little erractic it was reading 1.4ohms 1.6ohms 12 ohms 52ohms just basically random numbers so sometimes it would settle at 1.4 and then after a few seconds go erratic again.
Another thing is when i unplug the cam sensor it doesnt seem to make a difference to the engine also it doesnt throw a check engine light.
