AC doesn't blow cold.
- Saj77777
8 years 8 months ago #18185
by Saj77777
AC doesn't blow cold. was created by Saj77777
2005 Honda Odyssey EX
The high and low side stay at the exact same pressure, no matter engine off or on, AC off or on. I evacuated the system, however it could not pull a vacuum bow "0" on the gauge set.
I started to recharge the system, and both the high and low sides took a charge up to 60 psi, and wouldn't take anything more than that.
I'm baffled because, how can it not take a vacuum below 0 degrees mercury, but it CAN hold a charge without leaking?
I checked to be sure the clutch relay was indeed engaging. Then I verified 12V available on the load side of the relay. However, when I shorted the load contacts, there was no current flow, and the clutch did not engage.
- dkggpeters
- Thank you received: 13
8 years 8 months ago - 8 years 8 months ago #18194
by dkggpeters
Replied by dkggpeters on topic AC doesn't blow cold.
Sounds like you do not have your gauges set up correctly.
Last edit: 8 years 8 months ago by dkggpeters.
- Saj77777
8 years 8 months ago #18199
by Saj77777
Replied by Saj77777 on topic AC doesn't blow cold.
I doublecheck what you said made sure that I had the gauges set up properly.
Same thing.
Any other ideas?
Hold a charge but can't pull a vacuum. And the AC clutch does not engage at any time.
Same thing.
Any other ideas?
- dkggpeters
8 years 8 months ago #18200
by dkggpeters
Follow what is done on this video. If you still show 0 then you need to test that your gauges aren't faulty.
- Saj77777
8 years 8 months ago #18206
by Saj77777
YEP the gauge set was missing two seals.
