1993 Mercedes rough idle with engine shutoff
- WilliamBenz
10 years 1 month ago #1969
by WilliamBenz
1993 Mercedes rough idle with engine shutoff was created by WilliamBenz
Hi everyone. My 1993 Mercedes 400E has ~140K miles and I've owned it one year. During this time, it has run great - smooth, power, fairly fuel efficient, with an occasional, temporary rough idle on startup. I attributed those instances to using regular fuel when the 11-1 compression requires premium. While running using regular, it has been smooth. I've been using premium since. Fuel filter recently replaced.
The major symptom appeared suddenly while driving slowly through the city with no traffic and light throttle. The engine began sputtering and power died immediately which required its first tow in my ownership. Attempts to start the engine saw it turn over easily with a rare indication of firing. (Fuel pump and/or fuel accumulator?) Once towed home, it started immediately once off the truck and ran smoothly for a few minutes while parked.
How do I diagnose this car? What tools do I need? Thank you.
10 years 1 month ago #1990
Replied by Noah on topic 1993 Mercedes rough idle with engine shutoff
Hi william,
Based on the symptoms you describe, I would begin by testing fuel pressure. I'm no Benz guru, so It may be easier said than done!
I've seen cars die out and then restart after a tow with failing fuel pumps. All the jerking and bumping onto the truck can kind of jostle the pump like when you might strike the tank with a hammer to wake up a lazy fuel pump.
BUT, if prior Mercedes experience serves me, then your tank is in the trunk and the pump is mounted on the frame. Still, I'd want to know about fuel pressure.
The following user(s) said Thank You: WilliamBenz
10 years 1 month ago - 10 years 1 month ago #2003
Replied by Andy.MacFadyen on topic 1993 Mercedes rough idle with engine shutoff
What was it a particularly hot day ? Fuel system problems tend to show up in particularly hot or cold weather. Also what was the fuel level ? if the level was low it can show up fuel pump problems before they become apparent in normal driving.
It would help to know what model of injection system was on the car.
Last edit: 10 years 1 month ago by Andy.MacFadyen.
- WilliamBenz
10 years 1 month ago #2019
by WilliamBenz
Replied by WilliamBenz on topic 1993 Mercedes rough idle with engine shutoff
Hi Andy,
The weather was not hot. Fuel level was above half. I don't know how to learn what model of injection is installed. Thank you.
- WilliamBenz
10 years 1 month ago #2020
by WilliamBenz
Hi Noah,
The tow truck driver (FWIW) thought the same about jostling the car during loading, transport, and dropoff. The tank is in the trunk and the fuel pump is mounted underneath. Thank you.
- WilliamBenz
9 years 11 months ago #3719
by WilliamBenz
UPDATE: Car is running well. I went the ignition route and replaced plugs, each plug wire, two distributor caps, and one rotor. It's running well. I wasn't able to replace the ignition coil wires due to unfamiliarity with disconnecting the wires from the coils. Each coil is enclosed in a cover and access to each is limited. I wanted to replace the second rotor but the hex head of one of its mounting screws stripped. A low profile screw remover did not work. Cleaning the fuel injectors is next. Thanks for your help!
- WilliamBenz
9 years 10 months ago #3964
by WilliamBenz
Hi all,
The new plugs, rotors, caps, and wires fixed the major issue and appear to have fixed or improved two other electrical issues:
1. the auxillary electric fans would run randomly and when obviously not needed. They appear to run only as needed now.
2. some sort of electrical switch that sounds to come from behind the left side of the driver's dash would randomly switch on/off often. I presume it's a temperature sensor connected to the aux fans. I rarely hear it now.
