Toyota avensis 2008 1.8 lt 3zr fe engine
  • cyrus.nk
  • cyrus.nk's Avatar Topic Author
8 years 8 months ago #18348 by cyrus.nk
Am getting code c1231 steering angle sensor circuit.the sensor has 5 wires,1 ig + 2,12 volts hot always,2 signal wires and a ground.am getting 2.5 volts on one wire and the other wire 5 volts wen scoping CONNECTOR unplugged or plugged.any one knows how to reset this type of sensor and which communication line does it have or use.if i short to ground one signal wire i get code for communication bus off.
Sent from my SM-J730F using Tapatalk
