Low engineheat despite new thermostat.
  • Mathis
  • Mathis's Avatar Topic Author
8 years 8 months ago - 8 years 8 months ago #18482 by Mathis
Hello.
I have an issue and a theory.
The car is an -92 Ford scorpio 2.9 v6 and the complaint is low heat both in the car and at the gauge, the owner had already
bought a new thermostat and asked me to install it, so i thougt its no big deal...and love and behold it was nothing wrong with the old one, well i installed the new one and as i suspected the issue is still there, no heat!
She told me that its was wery good heat before and about a mounth ago it just happend, now its winter here in sweden and its 5 degrees F -15 c but the issue happend just 1 mounth ago and it was equally cold then and the car dosent warm up properly even inside my 77 degrees garage. The radiatorfan is a beltdriven "wiskos"-type (spell on that please) and its nothing wrong with it.
Now my hypothesis is a lean fuelmixture, i remember days ago when i had a mazda 323 carburator and start to fiddel with the carb and the same sympton appeard.
I suspect the fuelregulator because i did not get any response from the enginge when i disconected the vacuumhose, iam going to check this again with a fuelpressuregauge.
But can a lean or fat mixture cause this symptom or what is going on here? And yes the engine are running rough at idle.
//Mattias
Last edit: 8 years 8 months ago by Mathis.
8 years 8 months ago #18484 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Low engineheat despite new thermostat.
You really need to check the actual running coolant temperature of the engine, at the engine side of the thermostat or the by-pass (heater) hose.
Fords since the 1970s run a continuous flow of coolant through the heater matrix, inside temperature is controlled by blending hot and cold air. Low heater output with a good thermostat is usually down to either the water side of the heater being blocked or the heater air blending flap not moving. You should be able to hear the air blending flap move when you change the heater temperature setting.
8 years 8 months ago #18486 by Tutti57
Replied by Tutti57 on topic Re:Low engineheat despite new thermostat.
You may have already checked this but make sure it has enough coolant in it too.
8 years 8 months ago #18487 by Andy.MacFadyen
One thing that has a major effect on heater output and engine warm up time is antifreeze concentration, if the concentration is too high the coolant takes longer to reach working temperature, and because the viscosity is considerably higher flow through the heater is reduced and the actual heat transfer efficiency from the coolant to the metal of the heater matrix is reduced is reduced. If the car is running 60/40 antifreeze/water concentration the heater ouput will be lower than if it is running 40/60. 40% solution should protect down to -25c
The following user(s) said Thank You: CurrentDraw
  • Mathis
8 years 8 months ago - 8 years 8 months ago #18492 by Mathis
Replied by Mathis on topic Low engineheat despite new thermostat.
Thanks for the tips so far. but it is not just the inside-temp, it is the engine who dosent warm up, i use the tempgauge as a "witness" when the inside-temp drop so do the engine. If i warm it up inside the garage as far as it can be warmed up and after i take a spin i can littery grab every hose in the enginebay and put my hand on the block whitout burn my hand.
Over the phone i asked the owner to turn on the ignition and wait 2 min and guess what... a very long cranktime.
i suspect that the regulator is stuck open. Now my original question, can a lean fuelmixture cause this? i belive it can, whats your thoughts?
Thanks Mattias
8 years 8 months ago - 8 years 8 months ago #18512 by Andy.MacFadyen
One way to look at it any thermostat you buy for one of these could have being lying on a shelf for 20 or 30 years so the odds of finding a faulty one are quite high,
As to lean mixture a lean mixture makes an engine run hot --
Lean mixture = Slower combustion = More waste heat rejected to cooling system and exhaust.
Last edit: 8 years 8 months ago by Andy.MacFadyen.
  • Mathis
8 years 8 months ago #18519 by Mathis
yes thats one possibility except that it was nothing wrong with the old one.
Well there are more to that exept high temperature, it depends on the load and rpm the enginge running at, lean mixture lower the combustionspeed and temp do to lack of energy but the exhaustgastemp are increases
according to a Swedish expert.
Well i guess iam going to find out, i know for a fact that the thermostat is good, the only thing thats wrong that i found so far its a stuck fuelpressure-regulator, and thats was my guess from the start...a fuelmixture problem.
Its a wery interesting sympton non the less.
8 years 8 months ago #18542 by Noah
Replied by Noah on topic Low engineheat despite new thermostat.
Andy.MacFadyen wrote: One thing that has a major effect on heater output and engine warm up time is antifreeze concentration, if the concentration is too high the coolant takes longer to reach working temperature, and because the viscosity is considerably higher flow through the heater is reduced and the actual heat transfer efficiency from the coolant to the metal of the heater matrix is reduced is reduced. If the car is running 60/40 antifreeze/water concentration the heater ouput will be lower than if it is running 40/60. 40% solution should protect down to -25c
Thanks Andy! I was unaware of the effect of coolant concentration on heat!
Like any said, lean mixtures burn hot. I've heard of people running bigger jets in snowmobile engines to help keep engine temperature down, but i have never heard of a rich mixture on a car engine effecting the warm up time or heater output.
  • Mathis
8 years 8 months ago - 8 years 8 months ago #18543 by Mathis
yes the coolent is one thing i am going to check. Not rich but lean mixture. It happend to me on a mazda with a carb, At the time i didnt know what i was doing when i fiddel with it and the heat just went away, then i sqrewed back the screw and back was the heat again.
And then i found that the regulator on this ford is stuck open.
But who knows it can be a coincidence that the regulator failed approximately at the same time the owner added concentrated antifreeze, the owner do know jack shit about cars so.
To be continued
8 years 7 months ago #18593 by HD/MW Canada
Replied by HD/MW Canada on topic Low engineheat despite new thermostat.
You also need to make sure it is not air locked. You can air lock an engine, or the heater core or even both.
8 years 7 months ago #18639 by juergen.scholl
Replied by juergen.scholl on topic Low engineheat despite new thermostat.
A lean mixture will burn hot, so this won't be the cause of a low temperature concern.
[HOW] Did you make sure there's no air lock?
What happens when you block off the radiator inlet hose?
