1991 ford f150 5.0 o2 sensor stuck lean
  • Griffin
  • Griffin's Avatar Topic Author
1 year 9 months ago #78458 by Griffin
I did the test light  test going from battery positive to o2 signal wire to go rich ,but scanner only shows .218 volts not 1 volt . Does that means my pcm is bad ? Or can I do another test to verify.  Thanks everyone
1 year 9 months ago #78499 by ferris48
Replied by ferris48 on topic 1991 ford f150 5.0 o2 sensor stuck lean
check the signal wire direct at the computer. Voltmeter on computer, test light at o2 signal wire.
  • Griffin
1 year 9 months ago #79172 by Griffin
Replied by Griffin on topic 1991 ford f150 5.0 o2 sensor stuck lean
Thanks for taking your time. It shows 12 volts engine off
