2005 Ford Expedition dtc`s P0349 & P3045
  • rob24chevy
  • rob24chevy's Avatar Topic Author
8 years 5 months ago #19298 by rob24chevy
2005 Ford Expedition dtc`s P0349 & P3045 was created by rob24chevy
Got a 2005 with dtc`s p0349 & P0345. tested alt.and showed bad so replaced and swapped cam sensor codes came right back. Have Verus edge but new to the scope and not sure about settings or where to test at PCM. Any help greatly appreciated.
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
8 years 5 months ago #19301 by Dylan
Replied by Dylan on topic 2005 Ford Expedition dtc`s P0349 & P3045
There's a TSB for this. Might wanna check it out if you haven't already.
File Attachment:
File Name: TSB06-19-1...5.4L.pdf
File Size:126 KB
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
8 years 5 months ago #19302 by Dylan
Sorry missed the part where you said you already tested the alternator and replaced it. So the ripple test was bad?
8 years 5 months ago #19307 by Tyler
Replied by Tyler on topic 2005 Ford Expedition dtc`s P0349 & P3045
How does this one run? If there's not an obvious alternator ripple issue, then I'd tend to suspect a timing chain issue. :unsure:
If you could, hook up your Verus scope to the battery. Turn electric loads on as described in the TSB. Volts DC with the 'AC Coupling' set on. 1V scale should be plenty. 500ms time base. Record the min/max reading and let us know what you see. Or save the capture and send it to me at wrenchturnsyou@gmail.com.
