VW 4 wire engine temp sensor
  • jeoff82
  • jeoff82's Avatar Topic Author
8 years 7 months ago #19524 by jeoff82
VW 4 wire engine temp sensor was created by jeoff82
Trying to find some info on trouble shooting 4 wire engine temp sensors on VW's. I don't think Paul talks about 4 wire sensors and I cannot seem to find any info on them here either. Only info I can find about a 4 wire sensor is that the ECU might be taking a Kelvin measurement. What is the best way of testing these properly?
8 years 7 months ago #19525 by bruce.oliver
Replied by bruce.oliver on topic VW 4 wire engine temp sensor
Year model and engine and i can look it up for you to see what each wire does
8 years 7 months ago - 8 years 7 months ago #19527 by Tyler
Replied by Tyler on topic VW 4 wire engine temp sensor
We'll see what the wiring diagram has to say once we know the YMM, but I'm betting it's just a two wire ECT sensor and a gauge sender combined into one. ;) Being VW, the sensor probably goes into a plastic housing, so the sender has to have its own ground (instead of grounding into a metal housing).
Last edit: 8 years 7 months ago by Tyler.
  • jeoff82
8 years 7 months ago #19529 by jeoff82
Replied by jeoff82 on topic VW 4 wire engine temp sensor
Thanks is a 2005 Lupo 1.4I.
8 years 7 months ago #19530 by bruce.oliver
That vehicle isn't in the US. I had to go back to 2000 model year to see a coolant sensor with 4 wires.So I an't really tell you wire colors because yours may be different, but 2 wires is for the PCM and the other 2 wires is for the gauge. Not sure if that's how your car is set up but it probably is. What exactly is wrong with your car?
  • jeoff82
8 years 7 months ago #19531 by jeoff82
Thanks for the info. It is someone else's car with a P0118 code, I havent looked at the car yet nor a wiring diagram til Tuesday.
8 years 7 months ago #19532 by bruce.oliver
OK. If you have access to a wiring diagram it should be easy to tell whats what. 2 wires will be ground, 1 signal to PCM, and 1 signal to gauge. With the sensor unplugged the PCM should show -40 or so and with the PCM signal wire jumpered to ground the PCM should show max temp, whatever that is in Celsius. 150 degrees maybe, not sure
The following user(s) said Thank You: jeoff82
  • jeoff82
8 years 7 months ago #19533 by jeoff82
Thanks again.
