dodge caliber interesting a/c issue
  • charless01
  • charless01's Avatar Topic Author
8 years 7 months ago #19651 by charless01
dodge caliber interesting a/c issue was created by charless01
Hi, my 2009 dodge caliber has an A/C problem, its compressor its not receiving the variable positive voltage at the solenoid. Ground is good. I scanned this car and I got P0645 DTC (A/C Clutch Relay Control Circuit), it's weird because Dodge Caliber does not have an A/C clutch relay. Using my bidirectional scan tool I checked all the sensors and data that have to do with the operation of the A/C compressor, they were Ok. I think I found the problem: I unplugged the A/C pressure sensor wiring and checked one by one its theree wires. I got a good ground, a good 5 volt reference input but my signal wire was reading 5 volts which is interpreted by the PCM as 500 psi high pressure, the ECM will never turn my A/C compressor on. The problem is that this signal wired it's shorted to the 5 volt reference wire inside the electronic board (engine fuse box). I unplugged the C5 connector and the short went off. This is an intermittent fault because when I disconnect the battery I start the car again the air conditioning system works perfectly. I am not sure if the pressure sensor its good, but my question is: If at any moment the sensor fails and send a wrong pressure reading (e.g 5 volts), does this reading got stored at the electronic engine fuse and short my signal wiring? or is it more likely that this board itself is faulty? PD: refrigerant pressures are ok. Thanks for your help. I'll upload the wiring diagrams.
