Dead Caddy Battery
- journeyman
8 years 6 months ago #19664
by journeyman
Dead Caddy Battery was created by journeyman
2008 caddy DTS having it's way with me. Battery goes dead intermittently. It has been to Caddy dealer 2x & they gave up on it. New battery twice. Very little[less than .25v a/c ripple from alt]. Using a graphing multi-meter I have about 8-12 milli amps. However when graph is switched to digital, min/max set, in the time span of 2-3 hrs I have recorded as much as 225 milliamps. Last night, batt volts @ 12.6. This morning, batt volts @ 7.1. Again with the min/max set all day, takes about 3 hrs to record 200-225 max milliamps. Anyone point me in a direction? Thanks in advance. Also, less than .1 volt drop on pos & neg main cables.
- journeyman
8 years 6 months ago #19697
by journeyman
Replied by journeyman on topic Dead Caddy Battery
UPDATE- Disconnected lead to rear fuse block & now max milliamp draw over 8 hrs is staying below 40 mA. Removed all fuses powering bcm, re-connected rear fuse block & draw now still below 40 mA. Certainly appears to be bcm intermittently waking up & drawing battery dead. Opinions? Suggestions?
8 years 6 months ago #19728
Replied by Noah on topic Dead Caddy Battery
Just out of curiosity, when the abnormal draw occurs, how long does it remain? Does it stay "on" once it happens, or does it come and go?
8 years 6 months ago #19730
Replied by Andy.MacFadyen on topic Dead Caddy Battery
Even allowing for damage to the battery from the constant discharging-recharging it is suffering I think it would need more than the intermittent currents you are finding to go from 12.6 to 7 v overnight. I think you are looking at drain through a power circuit rather than electronics.
I have seen alternators that appear to work perfectly in voltage test but have so much leakage they will drain a battery in a few hours, in that case the clue was a fairly large spark when I disconnected or reconnected the battery.
- journeyman
8 years 6 months ago #19759
by journeyman
Seems to be very short but repetitive draw, then settles in once again to 12-30 mA.
- journeyman
8 years 6 months ago #19762
by journeyman
Would that type of alternator issue show up on the a/c ripple test? This one seems to stay at .25v a/c peak to peak. Also put a new battery from stock just for test purposes, left all bcm fusus out for weekend. Will report back on Monday with my findings.
- journeyman
8 years 6 months ago #19826
by journeyman
OK Monday morning & Caddy battery was @ 13.0 v after being connected all weekend with just bcm power fuses pulled. Certainly seems to point to bcm as any other time battery has been hooked up for more than 2 days resulted in dead battery. Any suggestions or thoughts are very much appreciated.
