2008 Saturn Vue 3.6L no start
  • johnbonifas
  • johnbonifas's Avatar Topic Author
8 years 6 months ago - 8 years 6 months ago #19751 by johnbonifas
2008 Saturn Vue 3.6L no start was created by johnbonifas
2008 saturn veu 3.6 installed timing chain i have 170 compression spark is good and i have injector pulse no codes won't start if i pulse the injectors it will start for one second then die i have a pintal hump and injector amp is 1 amp
Last edit: 8 years 6 months ago by Tyler.
8 years 6 months ago #19752 by bruce.oliver
Replied by bruce.oliver on topic 2
Have you done 3.6 timing chains before?
Do you have a scope? At least 2 channels
  • johnbonifas
8 years 6 months ago #19757 by johnbonifas
Replied by johnbonifas on topic 2
No this is my first one alldada said to use dots on left side & triangles on the right side yes i have a 4 channel scope Thank you for getting back to me
  • johnbonifas
8 years 6 months ago #19758 by johnbonifas
  • johnbonifas
8 years 6 months ago #19760 by johnbonifas
Yes i have a 4 channel i also posted how this timing was set first one i did if i didnt set it up right could you please tell me thank you
8 years 6 months ago #19764 by Tyler
Replied by Tyler on topic 2
You've got spark and injector pulse... How's fuel pressure? Or, will it run on an alternate fuel source?
  • johnbonifas
8 years 6 months ago #19765 by johnbonifas
No it will not run fuel pressure is 59 psi if i pulse the injectors it will start for a second and die
8 years 6 months ago #19767 by Tyler
Sure seems like the car wants to run. :huh: Did this one start/run before the chains? Wondering about a plugged exhaust.
You could try pulling the front upstream O2 and see if it seems to start any easier.
  • johnbonifas
8 years 6 months ago #19770 by johnbonifas
I did that this car came from another shop the customer said it ran when he dropped it off put new head gaskets in and they couldn't get it started i be leave i have it in time i did stage two then i went to stage one to start timing it
8 years 6 months ago #19771 by bruce.oliver
Replied by bruce.oliver on topic 2008 Saturn Vue 3.6L no start
You put new chains on? If so why did you replace the chains? or you re-timed the existing chains? Does it have 170 psi in all cylinders?
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
8 years 6 months ago #19774 by cheryl hartkorn
Replied by cheryl hartkorn on topic 2008 Saturn Vue 3.6L no start
what do you mean you pulse the injectors??
  • johnbonifas
8 years 6 months ago #19775 by johnbonifas
Replied by johnbonifas on topic 2008 Saturn Vue 3.6L no start
i used my scanner and i did a balance test all the injectors dropped the same tried starting it and it started and died wont start by it self
  • johnbonifas
8 years 6 months ago #19776 by johnbonifas
the other shop replaced the head gaskets and timed it wrong i re timed it and i have 170 in all cylinders
  • johnbonifas
8 years 6 months ago #19777 by johnbonifas
they replaced the head gaskets and used the old gears i had to re time it so i put new chain set in i have 170 in all cylinders
8 years 6 months ago #19778 by bruce.oliver
So do you have injector pulse while cranking? Or just when controlling with the scantool?
  • johnbonifas
8 years 6 months ago #19780 by johnbonifas
this is the first 3.6 i did i got this from another shop i looked it up on alldata i have a four channel scope
  • johnbonifas
8 years 6 months ago #19781 by johnbonifas
i have injector pulse while cranking and good spark
8 years 6 months ago #19784 by bruce.oliver
If it were me I would have to verify timing. Perform a relative compression test with an ignition sync from each bank
  • johnbonifas
8 years 6 months ago #19786 by johnbonifas
i will try that thank you
  • chief eaglebear
  • chief eaglebear's Avatar
8 years 6 months ago - 8 years 6 months ago #19795 by chief eaglebear
Replied by chief eaglebear on topic 2008 Saturn Vue 3.6L no start
Maybe a secondary ign wave see look at the resistance in wave see if you have a super lean mixture do a volume test even though injector pintle shows volume
Last edit: 8 years 6 months ago by chief eaglebear.
Time to create page: 0.360 seconds
