94 Toyota Camry No start/Possible overheating issue
  • Donnyten
  • Donnyten's Avatar Topic Author
8 years 6 months ago #19787 by Donnyten
Hey guys, its been a while since I've posted here. Since then i've been in the satellite TV industry for some time and kind of need a refresher a bit as I havent worked on a car in quite some time. Also would like some incite as to what has recently happened
As I was driving home, The car began ticking louder than usual, as if the valves were making excessive tapping noises, then the car shut off and i pulled to the side of the highway. I popped the hood to notice that coolant was boiling in the reservoir. There was no indication that the car was overheating while i was driving. The gauge stayed below middle where it usually is so hopefully the car has not overheated. There are no visible leaks anywhere. Oddly enough though, the car now will not crank over, yet the starter will click once, and thats it. The battery still has a full 12+ volts and all of my accessories work so it may be safe to say the battery is not the issue at the present time. When I get time I plan to have the starter tested and I will probably get a cooling system pressure tester to see whats going on. So, out the blue, i seem to be dealing with two separate issues, but would like to know if these two could be related somehow. No crank, possible over heating.
Thoughts?
8 years 6 months ago #19788 by bruce.oliver
Replied by bruce.oliver on topic 94 Toyota Camry No start/Possible overheating issue
Put a socket on the crank bolt and see if the engine will move by hand
  • Donnyten
8 years 6 months ago #19789 by Donnyten
I was afraid someone would suggest that
  • Donnyten
8 years 6 months ago #19831 by Donnyten
Ouch! Oil dipstick bone dry :-( time for a new car
8 years 6 months ago - 8 years 6 months ago #19851 by Tyler
Ah, sorry to hear sir. :( Seeing if the crank can turn by hand is a great suggestion.
You can also do a quick test of the starter/engine with your multimeter hooked up to the battery. Turn the key to crank and hold it there. If the meter stays above 10V, then the starter isn't drawing enough current, chase a starter issue. If it goes below 10V, let go of the key and make sure the engine isn't locked. :lol:
Last edit: 8 years 6 months ago by Tyler. Reason: reasons, fight me
  • Donnyten
8 years 6 months ago #19855 by Donnyten
Engine does not turn by hand and starter works :-/
8 years 6 months ago #19856 by Tyler
I was holding out hope! :lol: Well, I suppose you could make this an engine swap project? How's the rest of the car?
8 years 6 months ago #19858 by bruce.oliver
Tyler wrote: Ah, sorry to hear sir. :( Seeing if the crank can turn by hand is a great suggestion.
I have tried to teach a few techs that test. None of them trust it.lol Oh well, works for me
8 years 6 months ago #19859 by Tyler
bruce.oliver wrote: I have tried to teach a few techs that test. None of them trust it.lol Oh well, works for me
THANK YOU. I love that test, but I get all kinds of crazy looks when I use it. :silly:
The following user(s) said Thank You: bruce.oliver
8 years 6 months ago #19863 by bruce.oliver
When you understand electricity, at least a little, it makes sense. But most techs don't understand electricity at all. One of the guys I work with has been burned by open circuit testing multiple times and I've explained it to him multiple times. But he still does it. He just doesn't get it
8 years 6 months ago #19867 by BroncoMcbane
It works better with a clamp ammeter than a voltmeter. Even an inductive CSB load tester. And is most accurate with a fully charged battery.
The Thermoquad Cowboy
