Ford v10 not starting
- Tireman25
8 years 6 months ago #19799
by Tireman25
Ford v10 not starting was created by Tireman25
At my work we drive 2004 u haul. I think e350 with the v10. We got one that cranks but doesn't start. Did all the normal checks spark and fuel. All good. It has a head temperature sensor code. Will that keep it from starting. I know it helps with the timing from the computer. Just trying to help out my boss he's got it torn down and is a little stuck
8 years 6 months ago #19816
Replied by Tyler on topic Ford v10 not starting
A cylinder head temperature sensor code, correct? I dunno about timing, but that'll definitely change the cranking injection pulse width. I rarely see those fail, but if you wanted to rule it out, you could just disconnect it and try starting again.
So spark is present, what kind of fuel checks were done? Pulse, fuel pressure? Or, will is start and stay running on an alternate fuel source?
- Tireman25
8 years 6 months ago #19819
by Tireman25
Replied by Tireman25 on topic Ford v10 not starting
I'm not sure what kind of checks were done. I know it won't try and run at all. He's started by putting in a new crack sensor first and moved on to swapping out the ECU from another truck. Before he did that i checked the codes with my bluetooth obd2scanner. It also had a fuel rail pressure sensor code i can't remember exactly what it said. This probably isn't helping you help me much. On my 2004 Silverado i broke my coolant sensor once changing out my power steering pump. It wouldn't start once warm even with starting fluid. Thought maybe Ford would be the same
- cheryl hartkorn
- Thank you received: 130
8 years 6 months ago #19820
by cheryl hartkorn
Replied by cheryl hartkorn on topic Ford v10 not starting
what is the actual fuel pressure vs what the fuel rail pressure sensor reads? also the plugs might be fouled from cranking on it. have you checked compression??
- cheryl hartkorn
8 years 6 months ago #19821
by cheryl hartkorn
also have you checked for a stuck open egr valve/plugged exhaust?
- Tireman25
8 years 6 months ago #19827
by Tireman25
I will check that tomorrow. I'm sure he hasn't yet. He's really just jumping to the worst possible conclusion the ecu. I guess it could but not likely be that. Another thing about when stopped working. A guy was just driving it in the rail yard going 20mph. I guess it shut off then started again and died. Since then nothing not even a sputter of life. But I'll find the time to check the pressure gotta find one for compression. And hope i don't brake of a plug. Supposed to be a real pain in these engines. Seized and stripping issues.
- Tireman25
8 years 6 months ago #19828
by Tireman25
I haven't what's the best way to check exhaust. These trucks do just put around a train yard and sit running a lot. Our diesels used to plug up a lot. Is this a issue with gasoline?
8 years 6 months ago #19854
I guess a plugged exhaust is possible, but I figure it'd still start and idle if that were the case. For it to not start, both cats would have to be SOLID. :lol:
I'm with Cheryl about checking fuel pressure, as that's the most common reason I've seen for these not starting. If no one has tried it yet, you can always try feeding it carb cleaner or brake cleaner. If it starts, you know you're looking for a fuel delivery problem.
Does your Bluetooth scanner show live data? If you saw a fuel rail pressure code, then it's probably an electronic returnless system with a sensor on the rail. No gauge required! See if you find a fuel pressure PID in on your scanner. OR download ForScan - excellent software with access to OEM data.
- Tireman25
8 years 6 months ago #19868
by Tireman25
I didn't get to even try. He's got the ecu out and torn a part. The forscan is what I'm using. I'll look at the pid when possible. He did tell me he tried starting fluid with no luck at all. Yet says it had spark. He did replace the crack sensor. After watching a few videos before he tore it a part. The check engine light never turned off while cranking. I thought he would try and chase a wiring issue for the crank sensor. After i told him Ford light turns off. But nope straight out with the ecu. I'll let him just keep trying. I don't know he checked for spark i wasn't there. But it was after the sensor being replaced and trying the other ecu from another truck. He's going about it all wrong. I think. Just wanted some more ideas. Thanks I'll keep updated
