03 dodge Caravan ABS light on
  • Mort
  • Mort's Avatar Topic Author
8 years 6 months ago #19844 by Mort
03 dodge Caravan ABS light on was created by Mort
Just got in a 2003 dodge grand caravan with the ABS light on All I have is a multimeter and a test light. can someone give me a bit of guidance as to where to start I do have the service manual for the vehicle.
8 years 6 months ago #19848 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 03 dodge Caravan ABS light on
You would be better reading the codes from the ABS module and reading the live wheel speed sensor output to get direction. If you don't you end up playing wheel bearing and sensor roulette.
8 years 6 months ago #19850 by Tyler
Replied by Tyler on topic 03 dodge Caravan ABS light on
Andy.MacFadyen wrote: You would be better reading the codes from the ABS module and reading the live wheel speed sensor output to get direction. If you don't you end up playing wheel bearing and sensor roulette.
Definitely the way to go. See if a local parts store has a scanner that'll read ABS codes? Many of the higher end Global scanners will read the ABS and Airbag modules.
Once you have codes, we can recommend some pinpoint testing. :cheer:
